Idle problem
Old Jul 11, 2007 | 01:04 PM
David's Avatar
Default Idle problem
My 1996 850 GLTis idling unevenly. The car runs great when accelerating, just idles poorly. I have heard both Idle position sensor or Idle motor as possible culprits. Anyone have a thought?
Old Jul 11, 2007 | 01:26 PM
axelm's Avatar
Default RE: Idle problem
When was the last time you did basic tuning (plugs, wires, air filter, pcv, etc)?
Old Jul 12, 2007 | 03:07 AM
JPN's Avatar
JPN
Hello Dave,
Is the Check Engine Light on? If not, it could be as simple as a dirty throttle body that needs cleaning, or the ECU may have to re-learn idle, if the battery has been replaced lately. It may also be due to vacuum leak from rubber hoses or plastic elbows that are known to go bad after years.
As to tune-up items, refer to the following post:
https://volvoforums.com/m_48928/tm.htm
I hope this gets you started.
JPN
Old Jul 14, 2007 | 10:44 AM
JPN's Avatar
JPN
Here's another idle problem[8D].
JPN
[IMG]local://upfiles/6892/9FEAB2578543406CAD7F61190FFED289.jpg[/IMG]
Old Jan 21, 2008 | 08:49 AM
clintw's Avatar
Hi Everyone,
I am new to the forum and want to thank all of you guys for contributing to such a wonderfull site.It really is a gr8 help to a guy like me who here in South Africa lacks the aftermarket parts and accessories to help keep these gr8 cars alive.I have to buy very expensive Volvo original parts here and the labour rates are very expensive.
The reason I have responded on this thread is that I am trying to cure my 1994 850 T5 from an Idling problem. The car was serviced recently , but was merely oil, plugs filter etc.
If I rev it ,it seems to be normal but wont idle and usually stalls whilst driving.I have read similar threads and they all seem to mention Idle Control Valve,PCV system and vacuum lines, throttle body.
I have only tried cleaning the ICV and that seems to be functioning ok, can someone give me the resistance readings to check this and maybe the othere sensors correctly?
I dont have a repair manual at the moment but def see the sense in getting one soon.
I would appreciate if someone could also point me in the direction of a diagram showing the pcv and vacuum system that I should check for thispoor idling and stalling problem.
Old Jan 21, 2008 | 10:35 AM
JPN's Avatar
JPN
Welcome to the forum, I hope it is helpful to you.
Since your 850 is a '94 model, I would start by pulling codes from the ECU. I'm on my way to bed so I'll post a better reply in about 10 hours. Meanwhile, other members should be replying with solutions.
Cheers,
JPN
Old Jan 21, 2008 | 12:11 PM
axelm's Avatar
ORIGINAL: clintw
I feel your pain since I am in a similar situation here in Argentina. Parts for my old 850 cost the same here than what parts for a MB S65 AMG cost in Germany.
Old Jan 21, 2008 | 06:43 PM
Trevoro's Avatar
has any one got an evap code p0400?, aswell as system too rich? could this be caused by a bad maf or plugged pcv? also rpm reved high once all on it's own? any ideas?
rosesforlily
Nov 5, 2009 09:23 AM
kevmcrae
Apr 25, 2009 11:25 PM
yank50
Mar 14, 2009 11:15 AM
ss~zoso~ss
Jan 12, 2009 04:27 PM
toshields
Dec 8, 2007 04:50 PM
