idle problems Chek engine light need advised
Old Mar 5, 2009 | 03:25 PM
gabyman97596's Avatar
Default idle problems Chek engine light need advised
So i bought the car today and it has problem at idling starts misfring auto zone pull the codes is 1996 850 non turbo and the codes are the following:
p0705
p0103
p0120
p0730
Old Mar 5, 2009 | 08:05 PM
There is a wide range of codes there.
Mass flow
throttle position sensor
and tranny codes.
The mass flow and throttle position sensor might be bad.
Old Mar 6, 2009 | 07:57 AM
Psaboic's Avatar
I would clear the codes, do a FULL tune up, check all connections, and see if any of them come back.
Old Mar 8, 2009 | 01:23 AM
JPN's Avatar
JPN
Default Tune up list
My 2nd reply at the following thread should give you some ideas as to a full tune up.
https://volvoforums.com/forum/volvo-850-16/new-volvo-850-owners-read-important-thread-also-applies-s-v70s-9266/
JPN
Old Mar 8, 2009 | 08:54 AM
Okay i found out that the car had no air filter, I cleaned the throtter body and clean idle air valve and mass flow sensor and now the car is good @ idle and is running good i noticed the TCP is bad but that can wait for now i did the sparks and fuel filter and then i will erase the codes. now the bad is that is the pcv is clogged and is leaking oil from the oil cap
and i will want more information on the tranny codes what dop they mean because they don't apear on the chiltons manual that i haven thanks in advanced
Old Mar 9, 2009 | 03:05 AM
JPN's Avatar
JPN
313/P0705: Gear Position Sensor Signal Incorrect
213/P0120: Throttle Position Sensor Signal Too High
322/P0730: Gear Ratio Information Incorrect
P103.....?
I would first check on the tranny fluid level. The fluid level, unlike engine oil level, has to be checked with the engine running as well as the fluid being warmed up. Go to the following thread to find the procedure:
https://volvoforums.com/forum/showthread.php?t=9266
JPN
Old Mar 9, 2009 | 12:48 PM
Default : idle problems Chek engine light need advised
so I checked the trans fluid it was ok erased the codes took a long trip and only one code remains is the P0103 MAF and I will be doing this week the cap and rotor, spark plugs wires, fuel filter and some suspension things; but what can you tell me about the remaining code how can I test the mass Flow sensor??? thanks in advanced
Old Mar 9, 2009 | 12:56 PM
villagepc's Avatar
one other thing to check - check the connector that plugs into the MAF. My connections there were a lovely shade of green (corroded). I cleaned them out with a dental pick, 1000 grit sand paper... 12 ounces of.. .nvm
that would be on both sides of the connection. the MAF itself and the harness connector...
Old Mar 9, 2009 | 12:59 PM
thanks i would be checking on that now
jopower
Feb 23, 2013 02:11 AM
landy
Jun 12, 2012 01:16 AM
wendybee
Feb 25, 2011 12:55 PM
annamojo
Apr 18, 2010 11:52 AM
sharifsm
Feb 4, 2007 05:36 PM
