idle smoke on turbo... adding to a previous thread
Old Mar 31, 2007 | 05:02 PM
n4hen's Avatar
Default idle smoke on turbo... adding to a previous thread
Noob here, so please be gentle. Did a search on idle smoke and learned a lot about turbos causing this condition. However, let me give you some history on this car. PO just put a new turbo on it. Boost seems fine, no oil in coolant, vise versa. He stated the turbo had gone out and was just replaced. In previous posts, oil leaked through turbo when they went out. Question is, could residual oil in intake system/intercooler be heating up and smoking at idle. I only notice this when car is sitting idle for a while in hot conditions. Also noticed a little when first starting it. White lingering smoke with a hint of oil smell. Just changed the oil after PO added oil additive.
I've only had this a week so I don't have reference of how it acted. I did just add some injector cleaner to the tank and mileage has dropped considerably. But it was smoking before adding it.
I am also waiting on the odometer gear parts to do the fix. The link is quite helpful on the way to disassemble odometer and lifting dash cap.
Thanks
Old Mar 31, 2007 | 11:14 PM
JPN's Avatar
JPN
Default RE: idle smoke on turbo... adding to a previous thread
Hi,
Greetings from Yokohama, Japan.
The smoke is white, and a hint of smell. The coolant seems to be entering the combustion chamber, either from a leaky head gasket or around turbocharger gasket (if the turbo has water jacket in it, I've never disassembled the turbo so I couldn't tell exactly). Have the cooling system pressure tested at a shop. Also, keep an eye on the coolant level in the reservoir to see if it's dropping.
Here's a colour chart for exhaust smoke:
Blue: Engine oil
White: Coolant, or normal water vapour
Dark gray/Black: A/F mixture too rich, either fuel/emissions control problem or a tune-up is required.
I doubt if it is caused by residual oil in the intake, it should have been sucked into the engine under high RPM. Also, I wouldn't use any oil additive, as name-brand oil already has good additives in it. However, I would consider using synthetic/semi synthetic (synthetic blend) oil for turbocharged engines.
I hope this helps.
JPN
[IMG]local://upfiles/6892/E566B3C10DCE48AB8556FF6B296EFB7C.jpg[/IMG]
McTaydr
Oct 29, 2014 07:47 AM
sleddriver
Forum Issues
Mar 27, 2010 09:26 AM
elimont
Feb 11, 2009 03:31 PM
LoganVolvosrock
May 14, 2008 04:32 PM
REZN8
Jun 28, 2006 12:41 AM
