Ignition, ABS, burned-out bulb warning
Old Nov 4, 2018 | 11:25 AM
TonyS's Avatar
Default Ignition, ABS, burned-out bulb warning
This concerns a 1996 850, non-turbo, 220K miles. After I turn the key in the ignition to start the car, the ABS light turns on and the car won't shift out of gear. If I jiggle the key, the ABS light goes off, the car will shift out of park, but the burned-out bulb warning light comes on. This even though there are no burned out bulbs (headlights, turn signals, warning lights, brake lights). The bulb warning light stays on as I drive the car, which seems otherwise to perform as usual. I had a spare ignition switch (the electrical portion held in by two screws on the left side of the steering wheel) so swapped it out. That didn't make any difference. Ideas?
Old Nov 4, 2018 | 01:04 PM
the fact that you can wiggle your key to change the car's behavior would be enough for me to suggest its time to replace the ignition switch. Get that fixed first then you can see if there's any remaining issues.
Ray f
Sep 19, 2010 05:45 AM
Rev0verDrive
Mar 20, 2010 11:31 AM
blester
Jan 25, 2010 05:45 AM
geoffreyhensley
Sep 10, 2006 12:54 PM
zilinski6605
Jul 5, 2006 09:46 PM
