ABS/mixed bag of symptoms
Old Aug 29, 2006 | 07:32 PM
geoffreyhensley's Avatar
Default ABS/mixed bag of symptoms
I have a '97 850 R and occasionally when I start my car, the ABS light will remain on. I had this problem before and had the unit replace, but now there's something else going on. The car will not willingly shift out of Park. When you override the shifter lock, you can drive the car, but neither the speedometer, directionals, nor the head/parking/running lights function properly. (As a side note, the emergency flashers and the brake lights do function normally). Anybody have any advise?
Old Aug 29, 2006 | 09:13 PM
code33's Avatar
Default RE: ABS/mixed bag of symptoms
Ignition switch.
Jiggle the key and see if that does the trick.
This is common and very easy to replace. The switch is about $50.
Old Aug 29, 2006 | 09:14 PM
A bad Ignition switch will cause that.(Electrical part of the ignition switch)
Wiggle the key some after it is running and see if they start working.
Old Sep 2, 2006 | 03:18 PM
ciao-rich's Avatar
i had similar, https://volvoforums.com/m_32564/tm.htm
Rich
Old Sep 10, 2006 | 12:54 PM
That is EXACTLY the problem! Thanks guys!
platinum_ghost
Nov 7, 2012 12:41 PM
chef
Aug 22, 2008 07:57 AM
alexi3rdgen
Apr 30, 2008 11:21 PM
kannegaard
Jul 1, 2006 06:40 PM
jay philoon
Nov 24, 2005 03:34 PM
