INMotion ECU upgrade problem
Old Jun 23, 2009 | 01:47 PM
Saleen9090's Avatar
Default INMotion ECU upgrade problem
After about 4 months of considering, BSing, and beating around the bush, I am ready to order an ECU tune by INMotion. The thing is I have a T5-R ECU in my T5 (threw out the old one).
I called inmotion and they said they have done it like that on rare occasions but will not be able to gurantee anything.
What was different on the T5-R stock to give it the erxtra HP in the first place? Do I risk harming my engine?
Old Jun 23, 2009 | 03:48 PM
TIPSP's Avatar
Got Boost?
The T5 and T5-R put out the same power, or around the same, so you should be fine.
Wait for the experts to get on.
Old Jun 23, 2009 | 03:58 PM
Saleen9090's Avatar
T5 is 222 Hp
T5-R is 240 Hp
Does the T5-R have the bigger turbo?
Old Jun 23, 2009 | 07:50 PM
Legendsecko87's Avatar
I think the T5R has the T16 Turbo. It also only goes up to 240 for 30 seconds.
Old Jun 23, 2009 | 08:26 PM
TIPSP's Avatar
Got Boost?
yes, that is why they are about the same..... I would say it really wouldn't matter. for they use the same engine.
Plus the 15G turbo will handle a good amount of boost. What tune would you get for it? I would not go past 18psi if you have stock car (i wouldn't do more than 20 on that turbo).
Old Jun 23, 2009 | 09:17 PM
Saleen9090's Avatar
The car is old and I was thinking about 15 PSI.
That leads into my second question. The pricing for the inmotion tune is for stage II. It says you can increase from that as well as decrease from that performance.
Does this mean I need to tell them the performance I want????
Old Jun 23, 2009 | 11:57 PM
I think the 15T Turbos can only go up to 15PSI?
You just need to say you want better then stock performance? why decrease?
Old Jun 24, 2009 | 12:54 PM
TIPSP's Avatar
Got Boost?
The 15G is a interesting little thing. I is probably most effeicent ~15psi (I forgot what the flow maps look like.), but you can run the little bastard to 20psi. I wouldn't do that with a stock IC though. I believe tech has his @ 17psi? Of course you would have to have a tune to run 15+psi for the fuelcut. I am running the 13C, which is a tiny little crap, @ 15psi, which i know is out of its "efficiency" range.
15-16psi would be a good DD tune. not too fast, better than stock, just right.
Old Jun 24, 2009 | 01:03 PM
Saleen9090's Avatar
For those of you that have a tuned ECU... INMotion claims they have 208 different maps for the Volvo. Am I supposed to negotiate what I want?
Like should I tell them I want 16 psi followed by proper fuel cut? What else should I be asking about other than boost increase and a new fuel cut?
Old Jun 24, 2009 | 01:33 PM
Saleen9090's Avatar
Just got off the phone with INMotion....
They say if they map my T5-R ECU, my T5 car will still achieve 15 psi of boost but it will spool faster and die out at higher rpms.
If I sent them a T5 ECU it would perform like normal (later spooling) except it would be able to hold 15 psi at higher rpm.
I guess because the T5-R turbo is larger it is able to hold the pressure at high rpm.
Should I get the T5-R ECU tuned or should I buy a T5 off ebay for like $100 and send that in?
Old Jun 25, 2009 | 07:56 PM
First the T-5 (Actually only called turbo) both came with the 15G turbo. It is only the mapping that made the T5-R different.
There is a ton of people running t-5 chipped ECU's in a T5-R and vise versa.
The later GLT is a 13G turbo and T5 and R models use the 15G turbo's.
Old Jun 26, 2009 | 08:39 AM
Saleen9090's Avatar
So your saying that after I bought the T5-R ECU I technically own a T5-R?
Old Jun 26, 2009 | 12:49 PM
TIPSP's Avatar
Got Boost?
sort of
Just remember that the turbo will be most efficient with a 3" turboback exhaust and other supporting mods for the tune.....
Old Jun 26, 2009 | 06:16 PM
Saleen9090's Avatar
I'll remember that.
Old Jun 26, 2009 | 08:07 PM
Bascially yes you have a T5-R now.
Old Jun 29, 2009 | 09:34 PM
mk3less's Avatar
well minus the sexy T5R interior, wheels and front bumper
Old Jun 30, 2009 | 06:06 AM
  #17
Here is the official Volvo Press Release about the T-5R introduction. It claims a much lower psi than you guys are spouting and it claims the turbo is the same. Just a 7 second initial boost when you floor it.
https://www.customers.volvocars.com/...release_6.html
91shelby
Jun 20, 2011 06:56 PM
boostnm3
Jan 15, 2011 05:09 PM
Saleen9090
Mar 21, 2010 10:51 PM
bigern45
Aug 5, 2008 08:14 AM
S70driver
May 15, 2006 05:02 PM
