Installed my ARD tune
Old Sep 28, 2011 | 09:06 PM
MattyXXL's Avatar
Default Installed my ARD tune
So I got my ard tune today.... all I can say for now is WOW!!
Lucky has gone above and beyond with his tunes.
he fine tuned it for my port and polish, I have no more backfiring between 3500 and 4500 rpms.
Boost is smooth and the power is nuts.
He also installed the switch for the ardvark flasher...
But sadly I can not enjoy it for a couple of days..
I got so fiesty with it, I either popped a heater core o-ring, or the heater core, cause my floor is all wet now...
But I highly recommend ARD
Old Sep 28, 2011 | 09:37 PM
boxpin's Avatar
Sadly I have not been able to enjoy mine. Had to send it back. Will not boost over 12psi and redline is 6.5k. Lucky have been totally cool about it and is going to send me another flash. Hope it all goes well
Congratulations!
Old Sep 29, 2011 | 09:07 PM
Vmax's Avatar
Talking
Yes his remaps are on point, mine's strong at 16lbs and backs down to 14lbs at redline (6K rpms)...
just have to take care of the other parts that are starting to get weak.
Old Sep 30, 2011 | 10:20 AM
MattyXXL's Avatar
Forgot to tell you, we are a wiseco dealer at the shop, I put an email in to them to find out my cost on the piston kit..
Old Sep 30, 2011 | 10:28 AM
boxpin's Avatar
Awesome!
Lucky mailed mine back yesterday. I am hoping to give it a try Saturday. Fingers crossed.
Old Sep 30, 2011 | 10:52 AM
MattyXXL's Avatar
When you get it in we need more drag videos..
Old Sep 30, 2011 | 11:44 AM
MattyXXL's Avatar
Well I found something out from wiseco..
Viva imports their wiseco kits from Europe.
Wiseco does not make a Piston kit for the 850 in the US
BUT.... and this is a BIG BUT... Because we have been a dealer for wiseco for 20 years we get special pricing.
My cost for a CUSTOM made piston w/ rings, wrist pins, circlips, and bearings (full piston kit) in any finish (ie; Moly, forged, high compression) any size (in MM)
Would be $175 a piston set.
I would pass the savings on to you guys ofcourse.. that is $875 for a set of 5 + shipping ofcourse. and you can get them in any combination and size you want.
When I do my motor build Ill be ordering a set... may not be till january but ill let everyone know..
Old Oct 1, 2011 | 02:26 AM
Vmax's Avatar
Cool!
But truthfully I don't plan on any more mods after full exhaust because you know what, that's when the fun ends and the MORE POWER addiction takes over and gives you an aneurysm!
If I start pulling apart this motor i'll want BIG power. I don't think I have the energy/resources for a build like that...
Old Oct 1, 2011 | 12:03 PM
MattyXXL's Avatar
Bro, once im done with my list of parts to order, ill show you the list with prices, and once my motor is done next spring Ill let you take it for a rip you will want yours built that way...
im weighing my options and going as strong as I can but with in a budget of $2500 to $3000 including machine work..
Including;
H-Beam rods $500
Wave guide or Wiseco hi-compression pistons (Possible over bore) $700-$800
Grinded and balanced crank from falacon $150 (bearings included)
Moly bearings and rings (rings May come with the pistons)
Blue printed Port & Polished R-Exhaust manifold (150 for the manifold)
Blue printed Port & Polished Intake Manifold
Blue printed Port & Polished Head
18T or 19T not sure yet The turbo is going to be the most between $1000 and $1300
n/a cams and TB (already have them, cost $90 at the u-pick)
FMIC (might use the one off of my neighbors wrecked r32)
ARD Black or Blue
And alot more, but I have to run so Ill send you the list when Im done
Old Oct 1, 2011 | 04:06 PM
Vmax's Avatar
Red face
By the time you're done you'll need a set of Willwood BBKs to stop that rocket!
I'm just a bit lazy right now and would rather just maintain my car than make it any faster, i've almost killed myself once already after Lucky worked his magic.
I don't think I have the restraint with a built and ready T5 like that..
How much power to the crank do you think you'll make after all the motor work is done? So far just adding up th elist you have comes to around $2800.
Do you plan on any work to your gearbox?
BFR
Nov 6, 2013 03:40 PM
RightLeft
Jul 30, 2013 12:14 PM
Ryant5
Jul 27, 2013 09:10 AM
eriknorcal
Jul 20, 2013 02:33 AM
Turkey_Sandwich
Oct 22, 2012 10:17 PM
