instrument cluster light question
Old Jul 16, 2012 | 06:00 PM
Phil 850's Avatar
Default instrument cluster light question
I have a few lights out in my instrument cluster and everything I have read says to remove the dash pad and then unclip the instrument cluster to pull it out. If I remove the dash pad that means removing the CD deck in the glove box then the air bag bracket etc. Has anyone been able to just remove the screws on the drivers side of the pad and reach in to unclip the instrument cluster and push it out or do I need to remove the entire thing?
Also, how do I change the lights in the HVAC control unit?
Old Jul 16, 2012 | 06:38 PM
artbar92706's Avatar
Hi Phil,
I have read of others freeing the dash pad and removing the cluster as you have suggested, I would be very careful though if you do this because the dash can be very brittle and the lip where the pad inserts near the windshield can break quite easily. Im not too sure how you change the lights on the HVAC control unit, what I do know is that you have to remove the glove box in order to push it out, you might be able to push it out by removing the ash tray, but I am not too sure (suggestions anyone???)
A~
Old Jul 16, 2012 | 07:02 PM
You can push the HEAT AC unit out once the original radio or whatever is in it's place is out. Please wear gloves or you'll know why I say please wear gloves.
http://www.matthewsvolvosite.com/for...44908&p=219359
Old Jul 16, 2012 | 09:05 PM
Phil 850's Avatar
If I have to remove the dash pad I will replace every bulb I can find so if anyone has a list of bulbs and how many please let me know, I don't want to do this again for a few years at least.
Old Jul 16, 2012 | 10:09 PM
If all you're talking about is the Heater/AC head then all you have to pull to get to it is the radio, not the dash pad.
Sorry, you were talking about the instrument lights too.
Old Jul 16, 2012 | 10:14 PM
Remove the entire dash pad. Trying to dig the cluster from under it will only result in broken dash pad, top of dash and cluster pieces. It's all to brittle to try to get around it.
Here is my write-up on the cluster removal and one photo has all the light bulbs highlighted.
Dash Cluster Removal for the Volvo 850
To remove the ECC, pull the radio and push the ecc out from the back. WEAR THICK GLOVES AND PUT A TOWEL on your arms to protect them as well. If you don't, you may need stitches.
Old Jul 17, 2012 | 07:37 PM
theboneskes's Avatar
It is easy to remove to gauges... On the drivers side with the door open there is a plug next to the side window vent, remove the cover. use a Torx T25 and remove the bolt, remove the cover, then you will see another T25 bolt near the pillar to the roof, remove that. Then remove the Air/heat louvers on the drivers side and the two top ones in the middle, there are a T25 on the top of the vents(look under to see them), and two one the top side of the cluster. The dash pad lifts off on the drivers side, pull it slightly forward and lift it up. Remove the two harnesses on the top of the cluster, the tan 90 degree elbow on the left side if you have the turbo charged car, and some of the clusters have a harness on the bottom and is removed once you lift the cluster and start rotating it to get it out. I wish I had a video of it... there are four 5 watt bulbs along the top, and two smaller 3 watt bulbs in the digital part of the cluster.
850 Odometer Gear with Instructional Video & Dash Light Bulbs
That is a video of how to remove it, with new dash bulbs and a new gear for the odometer. I dont know where to find the video by itself....
Old Jul 17, 2012 | 09:09 PM
IPd is funny. They have about 50 video's on youtube showing people how to do stuff and there they are trying to sell that video for $30. SMH
cooper30
Jul 1, 2013 05:21 PM
volvo5volvo
May 29, 2012 05:46 AM
Beau98
Aug 30, 2011 09:50 AM
trooperone
Jun 24, 2010 07:16 PM
MikeySq
Oct 1, 2006 08:56 PM
