intercooler install
Cut and paste from other threads:
You have to drain the rad, and drop the rad/intercooler/ac condenser as an assembly.
You can let the condenser hang from its lines to get enough clearance to remove IIRC 4 bolts that attach the condenser to the rad. The intercooler is just sandwiched between them.
P.S. If you don't already know, there is only 2 bolts that hold in the assembly. One on either side on tabs that are on either side of the rad.
Second reply:
Rad removal is not needed. Tom some how removed mine in like 15 min with a hack saw. Remove the rad support and cut the top intercooler hole on the intercooler and it should come out after that
Link to answers:
How To Remove Stock Intercooler? - Performance Modifications - Volvospeed Forums
Video:
Second reply:
Link to answers:
Video:
Smoof
Aug 22, 2005 10:56 PM
