Intermittent ABS Light
Old Oct 4, 2008 | 03:00 PM
lowbeer's Avatar
Default Intermittent ABS Light
Hi,
From time to time, the ABS light on the dash illuminates. Does anyone know what this means? Is it a serious problem? Any information would be appreciated.
My car is a 97 Volve 850 Wagon with 255K on it.
Thanks.
Nate
Old Oct 4, 2008 | 03:34 PM
Default RE: Intermittent ABS Light
Most likely the ABS module is bad.
Old Oct 6, 2008 | 08:49 AM
Psaboic's Avatar
+1
Old Oct 6, 2008 | 10:54 AM
jks2's Avatar
Number of places on web that repair. I used BBA remanufacturing. Easy to take the module off and send it to them for repari. Cost me $79
Old Oct 6, 2008 | 11:39 AM
A couple of weeks ago I decided to open up the wife module and I saw what was wrong with the solder joints and repaired mine myself.
I haven't said much till now because I want her to drive it some before I said anything to make sure it was a good fix.
Old Oct 10, 2008 | 08:32 PM
mhphoto's Avatar
I used Module Masters. I was extremely satisfied with it. They even sent back the refurbished unit with a smiley face sticker. Cost was almost exactly $117.
Old Nov 2, 2008 | 01:26 AM
Raoul Duke's Avatar
I have the same issue. I knew this when i bought the car...and negotiated the price down for its replacement. But, if its something I can remove myself and just send off...that sounds GREAT! and ....a great way to save some dough.
that said....can i use the car without the module in it?
anyone got a link for a tutorial..or will a haynes manual cover this?
Old Nov 2, 2008 | 02:34 AM
The Edge's Avatar
You can drive without the module, but you will have no ABS (duh!!) and no speedometer.
If you have GPS or a satnav thiswon'tbea problem.
Old Nov 2, 2008 | 06:08 AM
You can send it here and he has a walk through for removal of it.
http://home.earthlink.net/~vicrocha/...vo_V70_ABS.htm
nealeas
Mar 24, 2018 09:59 AM
Scott V
2001-2013 model year V70
Feb 8, 2014 06:46 PM
piv15
Nov 3, 2012 07:56 PM
jg1
Mar 16, 2009 08:08 PM
