irratic power seat in the up position
Old Mar 30, 2005 | 02:46 AM
floryed's Avatar
Default irratic power seat in the up position
Hello there. I was wondering, I have a driver side power seat, and it works great leaning back, but comming back, I have to keep pushing the button because the seat only moves a small amount. What could be the problem?
Old Mar 30, 2005 | 01:09 PM
Default RE: irratic power seat in the up position
As long as the cable isn't bad you will need to calibrate it.Lean it all the way back then all the way foward even if it only moves a little at a time.Be patient once you move it both ways all the way it should be fine.
If not then the cable might be slipping.
Old Mar 31, 2005 | 04:45 PM
floryed's Avatar
Hey thanks! that worked GREAT!!! I slowly moved the seat into the lean forward position, and then went all the way back, and now the seat will go in both directions while just holding the button... like it should work. Again, thanks!
Old Mar 31, 2005 | 09:26 PM
No problem anytime.
edwardh
Dec 29, 2010 06:40 PM
lienmarine
Oct 20, 2009 03:49 PM
pleonard
Nov 17, 2007 09:30 AM
xjflexer
Feb 27, 2007 01:41 PM
DJboozeAlot
Nov 27, 2006 08:54 PM
