Jerking when in reverse (automatic)
Old Apr 5, 2015 | 07:33 PM
leeming's Avatar
Default Jerking when in reverse (automatic)
Volvo 850 2.5 GL wagon. 1996. 180,000 km. No problems with ATM so far, and the fluid level is good (I checked using the detailed instructions I found on a Volvo enthusiast's Youtube channel, which involved running the car until warm, going through the gears 5 seconds each etc before checking the level) The oil colour is gold and not burned or smelling.
In last 2 months I have noticed sometimes when in reverse the traction slips with a mild jerk. This happens when there is a bit of power added as when I am reversing out of our driveway which slopes upwards (ie reversing up a hill). No problems when reversing on the flat.
I live in a Pacific islands country with no Volvo dealer. Is this a sign the car is on the way out?
Old Apr 6, 2015 | 09:28 AM
Have you done a visual check for torn motor mounts or transmission mounts? Any other symptoms - ie clunks etc?
Old Apr 6, 2015 | 02:58 PM
leeming's Avatar
Thanks, I'll do that when I get a chance and refer back. Might have to ask someone with a lift. The symptom is slipping - ie the drive power to the wheels "slips". This causes a jerk
Old Apr 6, 2015 | 07:40 PM
hmmm. One other thought is to run the shifter from P to Lo about 20x to see if you can clean off the PNP switch contacts - (a long shot but can't hurt to try).
Old Apr 7, 2015 | 03:15 AM
leeming's Avatar
OK will do that, thanks a lot. I'll need to ask a workshop to check the mounts.
taz0001
Oct 15, 2021 10:43 AM
KarolynKaySays
Sep 23, 2010 05:13 PM
buttone
Aug 30, 2008 02:27 AM
jhop30
Sep 18, 2007 10:05 PM
Red XC
Oct 24, 2005 02:51 AM
