Jerking!!!!
Old Sep 10, 2007 | 02:27 PM
jhop30's Avatar
Default Jerking!!!!
HI I NEED SOME HELP!!!!! I have a 2000 S40 1.9...it has 85,000 miles on it right now. Now the issue is when the car idles, it vibrates its worse when its in drive and not so bad when its in neutral. Now the other problem is when I begin to drive it starts to jerk from second to third gear. Does anything have any familar experience with this problem...
Old Sep 10, 2007 | 02:38 PM
S70driver's Avatar
Default RE: Jerking!!!!
Ok "FORUM ISSUES" means just that. Issues with the FORUM itsself. Not car related issues.
Now I am going to move this to the proper section of the forum.
Next time I will delete the thread if it is posted in the wrong forum.
Old Sep 10, 2007 | 02:48 PM
jhop30's Avatar
I apologize!
Old Sep 10, 2007 | 03:29 PM
S70driver's Avatar
I wasn't trying to sound rude and I know that is how it came off.
However your not the only member that has done that.
Just be cacious of where you post your threads.
Old Sep 10, 2007 | 03:57 PM
jhop30's Avatar
will do..now is there someone that could help me or point me in the right direction for my problem please? I already have an apointment at volvo to have a dia. test to be done.....I just need to have a general idea of what to expect..
Old Sep 12, 2007 | 08:51 AM
JPN's Avatar
JPN
Hi Justin,
It seems that some of the engine & transmission mounts have given in. The average lifespan of rubber parts is 5 to 6 years.
As to shifting problem, I can only suggest that you check the transmission fluid for proper level, colour & smell. It should not have burnt smell, but 'm not sure what type of fluid is used on S40s so I'm not sure what colour it is. Also, have a visit to local AutoZone or other auto parts shop where they do free OBD-II diagnostic. Have the codes pulled from the transmission control module. Or, it may only need control cable adjusted. I do not have the service manual for S40, soI'm not sure about the specs on the cable.
Ask for Moderator Tech, Tech is the top-dog of the forum and he would be able to give you more accurate replies than I could possibly do.
Good luck,
JPN
Old Sep 18, 2007 | 10:05 PM
jojoswhip's Avatar
I would also have your plugs checked and coils. What codes came up when diagnosed?
taz0001
Oct 15, 2021 10:43 AM
alainm
Dec 22, 2013 03:07 PM
KarolynKaySays
Sep 23, 2010 05:13 PM
buttone
Aug 30, 2008 02:27 AM
Red XC
Oct 24, 2005 02:51 AM
