just bought a 1993 850 GLT
Old Aug 23, 2006 | 12:22 AM
Rexford310's Avatar
Default just bought a 1993 850 GLT
I have a few problems. She is a 1993 Volvo 850 GLT (no turbo). The original owner had it inspected, and i managed to get it registered, but still
Okay, the horn doesn't work, but the alarm does. The temperature gauge just stopped working a week ago. The engine moves forward about 2 inches when I put it in drive (its automatic), and i don't know if this is normal or not.
And finally, somewhat off topic, but if i installed an aftermarket stereo wouldn't there be a large gap?
Many thanks
[IMG]local://upfiles/6655/CF738691BB05447CB692BA025875E88A.jpg[/IMG]
[IMG]local://upfiles/6655/EEEEB83045B8475BA8926576EDA98F94.jpg[/IMG]
Old Aug 23, 2006 | 01:04 AM
m1964's Avatar
Default RE: just bought a 1993 850 GLT
It may need a new thermostat and temp sensor. Engine should not move so much, so check all motor mounts. There should be adapter to fit around aftermarket stereos -call Crutchfield -they give you adapter free if you buy HU from them.
Old Aug 23, 2006 | 03:21 PM
cranky's Avatar
The alarm horn is on the firewall - near the center, and near the top. The horns for the steering wheel are just behind the grill.
If you're mechanically inclined at all, change your own engine mount, or mounts. Most likely it is the large mount on top, and possibly the small mount under the bottom front. There are polyurethane replacements for the top mount - because the factory mounts go bad so often, but if you use it, know that it will transfer slightly more engine noise into the passenger compartment. I have one and am pleased with it. I would make sure that movement of the engine, didn't just unplug the temp sending wire, or something to that effect.
Have you checked your fuse panel for blown fuses?
Old Aug 23, 2006 | 06:49 PM
Rexford310's Avatar
all the fuses are good. I'm only 18 and my dad would go insane if he saw me doing stuff to the engine. I am taking mien volvo for a service september 1st and i will have them look at it.
thanks anywho.
Old Aug 23, 2006 | 09:12 PM
Dads850's Avatar
Horn: I'm thinking corroded connection on horn(s)
Temp gauge: Probably the temperature sending unit. It's connected to the upper radiator (I think) and is a piece of cake to replace.
Engine moving: Most likely upper engine mount as has been said.
Stereo: Yes, it's a double-din opening. You can get an install kit from Crutchfield and it works pretty well. Essentially you will have a single-din radio and a pocket for storage taking up the rest of the opening.
Old Aug 24, 2006 | 06:34 PM
gullyg's Avatar
In both my mate's 95 2.0ltr 855GL and my father's 93 2.5gl 855 there is a single spaced stereo and a "shelf' underneath.
You could have a look in scrapyards/breakers for the part that's missing from your car.
Old Aug 25, 2006 | 04:17 PM
Rexford310's Avatar
thanks. ok, next problem (i only got it for $2000).
I now seem to have a problem with mien volvo holding coolant. I got scared 2 days ago because a light came on. checked the coolant and it was below the min sign. so i put some coolant in and thought it would be ok. today i looked under the hood and saw that the coolant was almost at the min sign again.
now whats wrong?
HELP!!!![:@]
weismanfamily
Oct 12, 2013 12:09 AM
weismanfamily
Oct 8, 2013 01:35 PM
alexk243
Aug 4, 2011 12:24 PM
mopar318
May 31, 2011 03:35 PM
cameronnq
May 23, 2011 01:15 PM
