93 850 GLT, No Spark, Just Bought
Old Aug 1, 2011 | 11:41 PM
alexk243's Avatar
Default 93 850 GLT, No Spark, Just Bought
I recently purchased a 1993 Volvo 850 GLT with 160xxx miles on it, but has received a 97 850 engine in it with about 70xxx miles on it.
The issue is that there is not spark. It was sitting for a few weeks to a month and when it was tried to start it wouldn't. Most recent diagnostic has shown that there is no spark.
No sure were to start. Looking for a manual now and hoping to, with advise from you guys, be able to run some electrical test before having to replace parts.
Thanks, anything helps.
Old Aug 1, 2011 | 11:47 PM
91shelby's Avatar
sounds like a typical Cam sensor problem to me.
Old Aug 1, 2011 | 11:55 PM
alexk243's Avatar
So is there a way to test it before I drop the $100 on it?
Old Aug 2, 2011 | 12:03 AM
91shelby's Avatar
http://www.volvoclub.org.uk/tech/service/850/BasicTesting.pdf
Page 5 of this PDF should help
Old Aug 4, 2011 | 10:34 AM
alexk243's Avatar
ok tested the coil. Got battery voltage on the red wire and about 7 volts on the blue. what does this mean?
the manual says .7 to 1.5 volts is ok, but what does it mean if the voltage going to the coil is to high?
Old Aug 4, 2011 | 12:24 PM
alexk243's Avatar
Replaced Coil and cam sensor. Still showing the numbers above. Any idea what that means?
mopar318
May 31, 2011 03:35 PM
cameronnq
May 23, 2011 01:15 PM
blasta510
Oct 18, 2009 07:51 AM
Rexford310
Aug 25, 2006 04:17 PM
postdoc99
Apr 27, 2006 10:33 PM
