Just bought a 1996 850.
Old Jul 24, 2007 | 10:02 PM
  #21
quarterdimenickel's Avatar
Default RE: Just bought a 1996 850.
I just checked, and it turned just over 1.5 times before clicking.
Old Jul 24, 2007 | 10:08 PM
  #22
Also make sure the seal is good where the cap meets the filler neck.
Old Jul 25, 2007 | 10:06 AM
  #23
The guy I bought the car from said that there was a problem with the gas cap, and that he was going to get it fixed before we picked up the car (by his local mechanic, who specialized in European cars). So I just checked out the cap again, and it's actually brand new and made by an American company called "Stant". After rummaging around through the car, I found the original Volvo gas cap with the spare wheel, and put it on instead of the aftermarket one. It tightened about the same amount (1.5 turns) before it clicked.
The seals on both looked fine, although the seal on the original cap was faded. Which cap should I use?
While I was doing this, I noticed that there was a hole in the plastic below the filler neck. Is its purpose to drain spilled gas while you're refueling, or is it something else?
EDIT: I didn't notice any pressure or gas escaping when I took the cap off.
Old Jul 25, 2007 | 03:44 PM
  #24
Oh hell.
I know I said earlier that the gas tank wasn't leaking, but it certainly is. I just looked under the car, and the bottom half of the tank was wet (presumably with gas, but I didn't check), and every 15 seconds a decent sized drop would fall from the center of the tank.
Could this have caused the p0455 code? And how much should I be prepared to hand over to a Volvo dealer?
Old Jul 25, 2007 | 05:52 PM
  #25
Yes that will cause the code.
Usually a hose goes bad causing the leak.
Sometimes the tank cracks as well.
If it is the hose then it really isn't all that bad maybe like $100.00 to have it installed.
Old Jul 26, 2007 | 03:54 AM
  #26
JPN's Avatar
JPN
...and make sure to have it fixed asap, as the tank has now become a fire hazard.
Stant cap should be fine, as they are also sold at FCP Groton. Or, you could perhaps buy a Stant cap at a local auto parts store and use it as a "donor" for the O-ring[8D].
Speaking of O-ring, one O-ring for a B747's IDG (Integrated Drive Generator; equivalent of alternator) costs approx $100. The generator itself ranges between $100,000 to $300,000.....
Gentlemen, stay away from airplanes as much as you can!!!
Just kidding (but the prices are for real[8D]).
JPN
bluesb4sunrise
Jul 18, 2012 12:57 PM
jakes850glt
Apr 9, 2007 10:54 PM
postdoc99
Apr 27, 2006 10:33 PM
Demlotcrew
Nov 17, 2005 03:15 AM
Lichty17
Aug 3, 2005 09:52 PM
