Just bought an 850 T5 - Having a few issues
Old Oct 20, 2008 | 02:06 PM
valfrid's Avatar
Default Just bought an 850 T5 - Having a few issues
Hi,
Just bought a UK spec imported 1996 850 T5 estate but I have a few issues. I've had a scan through the boards and not found anything specific to these issues but if I have double-posted, don't shout at me too much, I'm new here!
Issues are:
Steering seems too light. Didn't these cars have variable power steering assistance that varied with speed? Mins constantly 'very light'
Rear pads rattle despite replacing them with a new set.
ABS light has been removed; not put it back in yet but brakes are fine but no ABS.
The reciver/dryer has rotted and needs to be replaced. I have a new one but how do I undo the top connector to it?
Thecambelt has been replaced but it's not running 'true'. I also get a whirring noise when I first start the car that appears to be coming from the cambelt area of the engine.
I think that's about it. Really would appreciate any help.
Thanks
Old Oct 21, 2008 | 06:23 PM
wheelsup's Avatar
Default RE: Just bought an 850 T5 - Having a few issues
ORIGINAL: valfrid
https://volvoforums.com/m_31445/tm.htm
Can you explain more? Is it not entirely on the gears?
Old Oct 25, 2008 | 02:18 PM
valfrid's Avatar
Thanks for the reply. I see that I need a special tool to detach the one connection which I'll source just now... Thank you for finding the link for me. The cambelt is on the gears- but only just. Also, when cold, there is a noise coming from the cambelt area which sounds like the belt itself 'running rough'.
Old Oct 25, 2008 | 09:39 PM
wheelsup's Avatar
Does it look like this?
The noise might be the belt rubbing against the plastic cover. There is a 12mm bolt in the center of the cover about 12" down, take it out then you can wiggle the timing belt cover up and out. Look on the inside and there is probably burnt out plastic, that's what mine had.
Old Oct 26, 2008 | 01:59 AM
MikeySq's Avatar
that looks scary[]
Old Oct 27, 2008 | 10:16 AM
wheelsup's Avatar
That's what the bad tensioner pulley from FCP made mine look like.
derrickb
Jul 13, 2012 12:24 AM
940Tgrl
Nov 28, 2007 08:24 AM
BigSection
Aug 10, 2006 12:26 AM
richsid
Jun 21, 2006 02:18 PM
Demlotcrew
Nov 17, 2005 03:15 AM
