Keep getting OBD 1 code knock sensor
Hello,
I've got a 95 Turbo, and every three days or so I get a code 143, knock sensor signal. Nearly everytime it's when I'm accelerating up hill. I can clear the code manually under the hood with the obd1 panel but it comes back on after a few days. Anyone else have this problem and a fix? I am using chevron premium 91 and I did a full tune up minus rotor and wires. New plugs, air filter, and even ran some fuel system cleaner. Thanks for any help.
LOL, that's a good one. Full tune up, minus wires and rotor. What date is on the wires that you decided not to replace?
If you have a knock code, you likely have a bad sensor, bad wires, or maybe even have timing off a little. There is a upgrade to the knock sensors and wires from what I have read on Volvo Parts, Accessories and Performance Specialist Since 1963.
