knock sensor issues on a 96
Old Jun 7, 2006 | 10:17 PM
snik's Avatar
Default knock sensor issues on a 96
hi guys
new member here, I apologize if this sounds like a newbie question
96 850 has had a new knock sensor put in but the knock sensor code keeps coming on again
I am suspecting that it may have been torqued too much.. would you happen to know how much I need to torque it?
also, is a faulty knock sensor code common on the 850? is there anything else that I can check?
thank you in advance
nik
Old Jun 7, 2006 | 11:52 PM
Default RE: knock sensor issues on a 96
Was the updated sensors installed?
Knock sensors torque specs=20Nm or 15FT LBS
You might also want to check the wiring and also maybe the Pins on the engine computer.
Old Jun 8, 2006 | 01:00 AM
snik's Avatar
ORIGINAL: tech
thank you so much
to be honest I am not sure if an updated knock sensor has been installed. Is there a particular feature unique to, or a part # printed on the new style knock sensors?
Old Jun 8, 2006 | 01:18 AM
If i remember correctly the old style has wires coming out of the sensors.
The new style the harness plugs into the sensors.
The old have a harness attched to the sensor.
rdklxprs
Jul 21, 2015 09:46 AM
andrewwhite149
Apr 22, 2012 01:33 PM
ruggles
Mar 3, 2010 04:19 PM
rp850
Dec 17, 2005 10:58 AM
lizard
Sep 1, 2005 08:48 PM
