loosening themostat housing bolts
Old Feb 7, 2009 | 03:19 PM
martinbarn's Avatar
Default loosening themostat housing bolts
What is the best way to loosen frozen thermostat housing bolts?
Old Feb 7, 2009 | 05:27 PM
JimKW's Avatar
PBlaster then make sure you have right size torx bit. Once you mess up the heads they will be a bitch to get out. Once I got mine out I replaced them with hex bolts.
Old Feb 8, 2009 | 08:07 AM
Psaboic's Avatar
+1 to replacing them with hex bolts!
Old Feb 8, 2009 | 10:32 AM
martinbarn's Avatar
thanks for the help.
Old Feb 8, 2009 | 12:39 PM
VJZ's Avatar
VJZ
Yes do replace them with hex head bolts.
It makes life so much easier for the next time you need to remove the goose neck/thermostat.
Luckily for me the previous owner did just that!
Old Feb 8, 2009 | 05:06 PM
Or go to the dealer and by the screws the new ones are supposed to be stainless steel.
Old Feb 9, 2009 | 09:14 AM
bestharry's Avatar
Well, if they are not damaged yet and are still tight in there. I suggest tapping them with the right torx bit inside with hammer on top before trying to open them. I guess this helps them to break the bond and makes it easier to loosen them.
Old Feb 10, 2009 | 05:29 AM
martinbarn's Avatar
Thanks to everyone for the advice. I did manage to get everything out, got a new housing (the old one was cracked) and got everything together.
martinbarn
Feb 7, 2009 06:44 PM
nottelybill
Nov 9, 2007 04:22 PM
robrike
May 15, 2007 12:14 AM
VolvoDriver
Oct 29, 2006 11:31 PM
ludeless
Mar 14, 2006 11:27 PM
