lost manual, oil info?
Old Mar 23, 2008 | 07:52 PM
blue_boi23's Avatar
Default lost manual, oil info?
so i "temporarily misplaced" my owners manual book and need a quick bit of information. Can somebody tell me the recommended oil amount for a 95' 850 turbo?
Old Mar 23, 2008 | 07:58 PM
Ozark Lee's Avatar
Default RE: lost manual, oil info?
Here is a link to your manual.
http://new.volvocars.com/ownersdocs/...0/95850_1.html
With the filter mine takes nearly 2 gallons.
...Lee
Old Mar 24, 2008 | 07:53 AM
JimKW's Avatar
I put 5.5 quarts in mine and then start it and check it and add until full. I think it calls for 5.8 quarts.
Old Mar 24, 2008 | 08:07 AM
JPN's Avatar
JPN
The factory manual states:
5.6 QTS for NA (including filter)
6.3 QTS for Turbo* (including filter)
*0.95 QTS for the oil cooler (it is not an absolute necessity to drain the oil cooler but I always do).
I usually fill the filter with clean oil, as well as coat the rubber gasket with thin film of clean oil. The filter on 850s attaches vertically onto the engine so it holds all oil during installation (unless you do the oil during severe earthquake[8D]), which is very nice. Then I dump 5.5 QTS without even thinking, and slowly add & check the dipstick to avoid overfilling.
JPN
Old Mar 24, 2008 | 08:37 AM
Psaboic's Avatar
All the above answers are just the info you need. The only bit of advice left that I can offer is for you to consider using synthetic oil. I never used to, but once I started I will not use anything else.
Glenn
Old Mar 24, 2008 | 09:49 AM
JimKW's Avatar
I use Valvoline High Mileage Super Blend 10W30 and only use Volvo or Mann filters and change every 3,000-4,000 miles.
nortons
Feb 22, 2015 11:14 PM
Ymss
Jul 4, 2011 11:27 PM
nicolaselias
Mar 24, 2011 08:48 PM
bdm8641
Oct 3, 2010 04:01 PM
robretpd
Aug 3, 2009 07:53 PM
