Tire Wear '95 850
Old Mar 24, 2008 | 11:00 AM
kirkgrau's Avatar
Default Tire Wear '95 850
Thanks to all who have helped with other problems with this car.
I am noticing that one of the front tires is down to the wear bars, but the other is not (actually has pretty good tread.) Both tires have the same mileage, but have not been rotated at all.
What would cause this unequal wear?
TIA,
Kirk
Old Mar 24, 2008 | 11:36 AM
JPN's Avatar
JPN
Default RE: Tire Wear '95 850
One tyre is probably out of alignment; have the alignment checked at a reputable shop. I usually go to the dealer for 4-wheel alignment but for the fronts, 850 uses simple McPherson set-up so any reputable shop should be able to do. It might have gone out of alignment due to a worn out suspension component.I would check forball joint, tie-rod ends for torn rubber boots,play, etc...
JPN
rangley1
Sep 10, 2017 05:09 PM
heyitsomid
Oct 11, 2008 06:46 AM
m1964
Jun 16, 2008 05:15 PM
BostonMike
Jun 16, 2008 05:12 PM
kcw12
Jun 10, 2008 08:48 PM
