M56L in local junk yard
Old Oct 31, 2010 | 09:36 AM
ibified's Avatar
Default M56L in local junk yard
There's a 1993 850 in the local yard with a manual transmission in it. I may be interested in grabbing this. Is there any difference between this and the M56H as far as installation and reliability/longevity goes?
Also, if the M56H is better, would the pedal box and shifter from this 1993 match up to an M56H?
Old Oct 31, 2010 | 04:40 PM
gilber33's Avatar
Brass shifter forks in the Hs, different speedometer sensor, and different drive ratios. Everything else is the exact same.
Old Oct 31, 2010 | 04:46 PM
ibified's Avatar
Is it any harder to install than the H? And what are the forks in the L made of?
Old Oct 31, 2010 | 05:00 PM
gilber33's Avatar
They're the exact same transmissions. You can't see any of the differences except that the L has a speed sensor on it and the H doesn't. They're made of plastic, but many people with built 850s are running them w/o issue.
Old Oct 31, 2010 | 05:14 PM
Mad Matt's Avatar
I have about 5k on my M56L so far. I took the trans out of a car with about 230K miles and it still Runs great!
Old Oct 31, 2010 | 06:13 PM
ibified's Avatar
Sweet. I'm probably gonna snag it then.
Old Oct 31, 2010 | 06:55 PM
gilber33's Avatar
Are you going to do a swap or just sell it?
If you're doing the swap, you'll need the transmission, transmission cables, shifter/shifter assembly, pedal assembly, etc etc.
Old Oct 31, 2010 | 07:32 PM
ibified's Avatar
Yeah, im gonna do the swap. I know I need to get all that stuff along with it, but thanks for making sure.
rspi
Apr 22, 2011 10:19 AM
ibified
Jun 9, 2010 09:04 PM
81sidewayswagon
Apr 12, 2010 11:06 PM
Titan Joe
Feb 6, 2010 03:05 AM
Kcpets
Jan 11, 2010 02:39 AM
