manual tranny?
Old Feb 8, 2010 | 08:46 AM
radio16's Avatar
Default manual tranny?
what model volvo has a manual transmission that i can just bolt on to my 850 turbo plat ??
Old Feb 8, 2010 | 08:55 AM
gilber33's Avatar
In the US, only NA 850s have the manual trannys. And you need one from a 96/97.
Old Feb 8, 2010 | 05:56 PM
radio16's Avatar
sweet there is one at the pick and pull its a 96 850 n/a --- IM ON IT LIKE STINK ON A TURD!!!!!
WOOT - wonder how much itll cost and how badly damaged it is
ill need the pedals and the shifter and linkage anddddddd??
thatll mean i gotta pull my moto completely out too right??(poop) ohh well nothing like the experience ,eh??
if the VOLVO RACING guys can do it all in 15 min out / swap trans and back in in --then i can too -----NOT!!!!
I CAN STRIP ONE DOWN TO THE OIL PAN AND REASSEMBLE IT IN A DAY THO - THATS GOTTA COUNT FOR SUMTHIN
L.M.F.A.O.
Old Feb 8, 2010 | 08:22 PM
gilber33's Avatar
What you'll need: Tranny, linkages, pedals, and shifter. That's about it from the car.
Now, not from the car, you need a clutch kit, RMS, axle seals. By rights you should get a new master and slave cylinder. I'm reusing my slave cylinder, but the guy that I got my kit from threw in a new T-5 master cylinder. You will also need your flywheel resurfaced.
Read this just to make sure you know what it takes. Also, talk to tech, he recently just did a manual and is supposed to be doing a write up on it (hopefully he does it soon!!)
Parts Bible
What You Need to Know
Old Feb 8, 2010 | 08:27 PM
Yes hopefully it will be completed soon!! LOL
You will also need to eventually find either a manual tranny ECU for Europe or Canada.
But it will run with the auto ECU(which I am now) Or save up and get the Auto ECU chipped and changed to a manual ECU.(Which some people are working on from what I hear)
It took me a day at work with both cars on lifts and swapping parts from one car to the other and vise versa.
Old Feb 8, 2010 | 08:41 PM
gilber33's Avatar
Pretty much all tuning companies have manual ECUs, the only problem is that no one has been able to keep the OBDII with a manual tune, that they're still working on. Except one, Turbo Tuner, which is just starting to become more popular here. Their tunes are ~$900, but what they do is add a USB port to your ecu, so you do all of your tuning, and from what I've read/heard, it's extremely user friendly and the customer service is great, they have also figured out how to keep your OBDII port active with the manual tune. I plan on running TT with my build.
Old Feb 8, 2010 | 08:44 PM
I wish I could afford one.
Old Feb 8, 2010 | 09:35 PM
gilber33's Avatar
Hopefully I'll be able to. I'm going to have to hold off on some other things that I wanted to do, but oh well. A reputable tune is what, $700? For $200 more you could get TT and never have to buy a tune again.
Old Feb 8, 2010 | 09:50 PM
True!
Old Feb 9, 2010 | 06:30 PM
jnduke's Avatar
I talked to the IPD guys and they said that when you run thier ECU you set the gear indicator to nuetral somehow. He said that the motor is getting load info from the other sensors. I was curious If I got an ECU flash now with auto, would I need a new one with a Manual?
Radio16- a great suggestion if possible- is get the whole car to your place and do a side by side swap. that's how I plan to do my swap from the one I found in my town. The guy knows me and said when I fininsh the bring the car back sans trans. We ahven't worked out the details yet, I'm waiting on TECH's write-up.
Old Feb 9, 2010 | 08:24 PM
gilber33's Avatar
The car will drive perfectly fine with an auto tune and manual tranny, tech said he's been doing it ever since he did his swap, you'll just have a CEL for missing TCU.
Old Feb 9, 2010 | 08:27 PM
Well there is a few idling issues I have as well but no big deal. On cool days when you first get in and go the first couple of shifts the idle hangs at like 1500.
Also from time to time sitting at a stop the idle will jump up to 1500.
Block91
2001-2013 model year V70
23
Apr 3, 2020 09:53 PM
montysano
Sep 25, 2006 09:54 PM
Ihatespeedbumps
May 22, 2006 05:38 PM
Ihatespeedbumps
Apr 14, 2006 09:28 PM
knight rider
Apr 28, 2005 12:20 PM
