map sensor - GM part? in my volvo!????
I've been having some real issues with my 1996 volvo 850 GLE, hard to start (turn over for 6+ tries before it fires), then it idles for a little and sputters and stalls, then when its finally going it bucks and surges and/or nearly dies as I accelerate, the weird thing is when I get above 2500 rpm all is good and the car drives great.
There are no codes, I have a B5252FS engine
I replaced the fuel filter, dist. and rotor pin, plugs, air filter, cleaned the throttle body, new throttle position sensor...still no luck. now my flex is ripped from all the bucking.
today I started it up and just before it sputtered to a stall I pulled off the map sensor vacuum line, the idle returned to a some what normal rate (a little hunting) when I returned the vacuum line it went back to the sputtering, pulled the line again and rpms ramped back to normal, I repeated this several times. I'm no mechanic but I think I have a faulty map sensor, the kicker is my map sensor has a big GM stamp on it (Gahhh!) and I can't find any part on line, but it looks like this...
http://wzfulai.en.alibaba.com/produc...AP_SENSOR.html
they list the OE number as this...60811534 19204S 594607
any help or advice would be appreciated...I wan't my volvo back "sob sob"
yes, map sensor just removed from my 1997 v70 (b2525s) was a gm one! new one came from ebay and works fine £29 a-zparts4u mS002 from fuelparts (which is where most motor factors get their bits from match up your engine model with what is available, some are a lot more expensive one or 2 are cheaper, cross reference as much as you can, the ebay id number for mine was 270353342754, but obviously that one is closed, you might get a link to it though here is the detail
THIS BRAND NEW MAP SENSOR (MS002) FITS TO :
CAR MAKE
MODEL
ENGINE NO
DATES
DESCRIPTION
VAUXHALL
ASTRA
X14NZ
2/96-8/98
1.4i Ecotec SOHC 8v Hatchback, 1389cc
VAUXHALL
ASTRA
C14NZ
8/90-8/98
1.4i SOHC 8v Hatchback, Saloon, Estate, 59bhp, 1389cc
VAUXHALL
ASTRA
X14XE
2/96-8/98
1.4i Ecotec DOHC 16v Hatchback, Estate, 89bhp, 1389cc
VAUXHALL
ASTRA
X14XE
2/98-4/00
1.4i DOHC 16v Hatchback, Estate, 89bhp, 1389cc
VAUXHALL
ASTRA
X16SZ
3/93-4/97
1.6i E-drive Ecotec 8v Saloon, Hatchback, Estate, Convertible, 69bhp, 1598cc
VAUXHALL
ASTRA
C16NZ
1/96-8/98
1.6i 8v Saloon, Hatchback, Estate, Convertible, 74bhp, 1598cc
VAUXHALL
ASTRA
X16SZR
2/98-
1.6i 8v Saloon, Hatchback, Estate, 74bhp, 1598cc
VAUXHALL
ASTRA
C16SE
3/92-8/98
1.6i SOHC 8v Hatchback, Saloon, Estate, 99bhp, 1598cc
VAUXHALL
ASTRA
X16XEL
8/94-8/98
1.6i Ecotec DOHC 16v Hatchback, Saloon, Estate, 99bhp, 1598cc
VAUXHALL
ASTRA
X16XEL
2/98-
1.6i DOHC 16v Hatchback, Saloon, Estate, 99bhp, 1598cc
VAUXHALL
CAVALIER
X16SZ
8/93-10/95
1.6i Ecotec Saloon, Hatchback, 69bhp, 1598cc
VAUXHALL
CAVALIER
C16NZ
9/91-8/94
1.6i Saloon, Hatchback, 74bhp, 1598cc
VAUXHALL
CAVALIER
C18NZ
9/90-1/96
1.8i SOHC 8v Saloon, Hatchback, 89bhp, 1796cc
VAUXHALL
COMBO
C14NZ
4/93-2/01
1.4i SOHC 8v Van, 59bhp, 1389cc
VAUXHALL
CORSA
C12NZ
4/93-8/98
1.2i 8v Hatchback, 44bhp, 1196cc
VAUXHALL
CORSA
C14NZ
4/93-3/99
1.4i 8v Hatchback, 44bhp, 1389cc
VAUXHALL
CORSA
C14SE
4/93-3/99
VAUXHALL
CORSA
X14XE
8/94-10/00
1.4i Ecotec DOHC 16v Hatchback, 90bhp, 1389cc
VAUXHALL
CORSA
X16XE
9/94-10/00
1.6i GSi, Sport Ecotec DOHC 16v Hatchback, 104bhp, 1598cc
VAUXHALL
MONTEREY
8/93-11/99
3.2i SWB, LWB SOHC 24v 4WD Utility-vehicle, 175bhp, 3165cc
VAUXHALL
NOVA
C12NZ
2/92-3/93
1.2i Hatchback, Saloon, 45bhp, 1195cc
VAUXHALL
NOVA
C14NZ
8/90-3/93
1.4i Hatchback, Saloon, 59bhp, 1389cc
VAUXHALL
NOVA
C14SE
2/92-3/93
1.4i SRi Hatchback, 82bhp, 1389cc
VAUXHALL
NOVA
C16SE
2/92-3/93
1.6i GSi Hatchback, 100bhp, 1598cc
VAUXHALL
TIGRA
X14XE
11/94-1/01
1.4i Ecotec DOHC 16v Coupe, 89bhp, 1389cc
VAUXHALL
TIGRA
X16XE
11/94-8/00
1.6i Ecotec DOHC 16v Coupe, 104bhp, 1598cc
VAUXHALL
VECTRA
X16SZR
10/95-5/02
1.6i Ecotec SOHC 8v Saloon, Hatchback, 74bhp, 1598cc
VAUXHALL
VECTRA
X16XEL
10/95-5/02
1.6i Ecotec DOHC 16v Saloon, Hatchback, 99bhp, 1598cc
VAUXHALL
ZAFIRA
C16SEL
4/99-8/00
1.6i 16v MPV, 99bhp, 1598cc
VAUXHALL
ZAFIRA
X16XEL
4/99-8/00
VOLVO
S40
B4164S
4/97-4/99
1.6i DOHC 16v Saloon, 105bhp, 1596cc
VOLVO
S40
B4164S2
4/99-
1.6i DOHC 16v Saloon, 109bhp, 1588cc
VOLVO
S40
B4184S
3/96-4/99
1.8i DOHC 16v Saloon, 115bhp, 1731cc
VOLVO
S40
B4184S2
4/99-
1.8i DOHC 16v Saloon, 122bhp, 1783cc
VOLVO
S40
B4204S2
4/99-
2.0i DOHC 16v Saloon, 136bhp, 1948cc
VOLVO
S40
B4204S
3/96-4/99
2.0i DOHC 16v Saloon, 140bhp, 1948cc
VOLVO
S70
B5202FS
1/97-4/99
2.0i SOHC 10v Saloon, 126bhp, 1984cc
VOLVO
S70
B5252S
1/97-1/00
2.5i SOHC 10v Saloon, 144bhp, 2435cc
VOLVO
V40
B4164S
9/98-4/99
1.6i DOHC 16v Estate, 105bhp, 1596cc
VOLVO
V40
B4164S2
4/99-
1.6i DOHC 16v Estate, 109bhp, 1588cc
VOLVO
V70
B5202S
1/97-9/99
2.0i SOHC 10v Estate, 126bhp, 1984cc
VOLVO
V70
B5252S
1/97-9/99
2.5i SOHC 10v Estate, 144bhp, 2435cc
CAR MAKE
MODEL
ENGINE NO
DATES
DESCRIPTION
VAUXHALL
ASTRA
X14NZ
2/96-8/98
VAUXHALL
ASTRA
C14NZ
8/90-8/98
VAUXHALL
ASTRA
X14XE
2/96-8/98
VAUXHALL
ASTRA
X14XE
2/98-4/00
VAUXHALL
ASTRA
X16SZ
3/93-4/97
VAUXHALL
ASTRA
C16NZ
1/96-8/98
VAUXHALL
ASTRA
X16SZR
2/98-
VAUXHALL
ASTRA
C16SE
3/92-8/98
VAUXHALL
ASTRA
X16XEL
8/94-8/98
VAUXHALL
ASTRA
X16XEL
2/98-
VAUXHALL
CAVALIER
X16SZ
8/93-10/95
VAUXHALL
CAVALIER
C16NZ
9/91-8/94
VAUXHALL
CAVALIER
C18NZ
9/90-1/96
VAUXHALL
COMBO
C14NZ
4/93-2/01
VAUXHALL
CORSA
C12NZ
4/93-8/98
VAUXHALL
CORSA
C14NZ
4/93-3/99
VAUXHALL
CORSA
C14SE
4/93-3/99
VAUXHALL
CORSA
X14XE
8/94-10/00
VAUXHALL
CORSA
X16XE
9/94-10/00
VAUXHALL
MONTEREY
8/93-11/99
VAUXHALL
NOVA
C12NZ
2/92-3/93
VAUXHALL
NOVA
C14NZ
8/90-3/93
VAUXHALL
NOVA
C14SE
2/92-3/93
VAUXHALL
NOVA
C16SE
2/92-3/93
VAUXHALL
TIGRA
X14XE
11/94-1/01
VAUXHALL
TIGRA
X16XE
11/94-8/00
VAUXHALL
VECTRA
X16SZR
10/95-5/02
VAUXHALL
VECTRA
X16XEL
10/95-5/02
VAUXHALL
ZAFIRA
C16SEL
4/99-8/00
VAUXHALL
ZAFIRA
X16XEL
4/99-8/00
VOLVO
S40
B4164S
4/97-4/99
VOLVO
S40
B4164S2
4/99-
VOLVO
S40
B4184S
3/96-4/99
VOLVO
S40
B4184S2
4/99-
VOLVO
S40
B4204S2
4/99-
VOLVO
S40
B4204S
3/96-4/99
VOLVO
S70
B5202FS
1/97-4/99
VOLVO
S70
B5252S
1/97-1/00
VOLVO
V40
B4164S
9/98-4/99
VOLVO
V40
B4164S2
4/99-
VOLVO
V70
B5202S
1/97-9/99
VOLVO
V70
B5252S
1/97-9/99
_val
Aug 26, 2014 12:03 PM
