metallic noise under glove compartment/dash
RE: metallic noise under glove compartment/dash
Is this sound like a loose metals hitting each other? or is it like a screetching noise? What is the frequency and is triggered by jumps/jerks?
If its close to the second then it could be from your blower motor ceasing. you can isolate that by turning the blower off as soon as you hear it.
seems more like loose metals at each other. Definitely is not the blowe ´cause it happens when it is off. sometime begins even in idle in the garage.After a while it vanishes and then suddently happens again. I cant find a pattern for it to happen.
Thanks.
Thanks.
