Michael
Michael
Light 21 engine electrical on no faults stored abs light intermittent come on for ages then it will go out for days then come on again then go off no codes stored light 21 lambada censor battery alternator earth straps anything else I need to look for please abs I've given up on this one any ideas even look underneath driver seat
what year/model? which light are you referring to? The ABS light can be caused by either a faulty speed sensor or a problem with the ABS controller board. Late 90s/early 00s models were prone to developing cracks in the solder in the ABS board. Several services will rebuild your board or you can swap in another controller (bolts to the ABS pump so you don't need to open up the brake lines).
