More climate control issues...
Old Nov 22, 2010 | 01:48 PM
mmyers024's Avatar
Default More climate control issues...
This is my second post on this problem. In the beginning I had no control over my HVAC and the AC and RECIRC lights were blinking so I replaced the control unit. That worked (but the lights were still blinking) and I now had control and everything worked fine for a while. Now all of the sudden I am back to square one with absolutely no control over the system. No buttons or slides work at all. I checked the codes and they are below:
315 - Recirculation Damper Motor Shorted to ground or power
323 - Ventilation Damper Motor Active too long
325 - Recirculation Damper Motor Active too long
411 - Pass. Comp. Fan Overcurrent or seized fan
414 - Driver's side temp sensor intake fan seized
Being that there are 5 different codes I don't know where to start. I have looked around the forum but every post I can find the person has some kind of control over the unit. Once again I have no control at all. Thank you so very much for any help that you can provide.
Old Nov 23, 2010 | 09:15 AM
mmyers024's Avatar
I reset my DTC last night and now I'm only getting the one fault:
What would that one fault be? I here a faint click sound when I try to turn the fan on or up. Again, nothing is working at all. Sorry about the double posts, I forgot I already replied to the earlier one. Thanks in advance for any help you can give me.
keyul
Jul 8, 2009 06:27 PM
madador
Dec 16, 2008 11:43 AM
thejobark
Jan 30, 2007 01:30 PM
jfikentscher
May 31, 2006 09:58 PM
vict8r
Oct 26, 2005 01:04 AM
