Must odor in A/C when turned on
Old Jun 23, 2006 | 12:28 PM
skyman's Avatar
Default Must odor in A/C when turned on
I have a bad musty odor that comes from the A/C when first turned on. It seems to lessen after it has been running. My mechanic says it is a frequent problem that is due to fungus on the evaporator. He said that a spray is made just for this problem and that it should be sprayed on the evaporator. The problem I am having is getting to the evaporator to spry it. Has anyone else dealt with this problem? Thanks
Old Jun 23, 2006 | 03:41 PM
billofdurham's Avatar
Default RE: Must odor in A/C when turned on
A common problem and to really get at the evaporator means taking out the dash - strange place to put it!
I remove a couple of the vents and spray Febreze or similar into the ducts. That usually holds the smell at bay for a couple of months but unfortunately does not remove the cause which is the mould on the fins.
Old Jun 24, 2006 | 04:45 AM
t.d.'s Avatar
Go to WWW.Airsept.com
They make the product to do this and it comes in a kit. Mazda, GM, Ford and Mitsubishi are OEM providers of the product so they have the special nozzle to get to the evaporator to do this. Get the product and go to a dealership and ask them to apply it.
Old Jun 27, 2006 | 12:36 AM
Also replace the Pollen filter.
denver005
Apr 28, 2010 05:16 PM
jg1
Apr 23, 2010 05:56 PM
slowwhale
Aug 21, 2008 10:50 PM
Kimmen
Mar 16, 2008 01:07 PM
850forum
Feb 25, 2007 01:51 AM
