My heat/AC won't work
Old Nov 4, 2008 | 03:02 PM
MI_Marcus's Avatar
Default My heat/AC won't work
I am in need of some help.
I have a 1995 850 turbo wagon with ECC. I just replaced both my blower motor and blower motor resistor (the dealership I take my car to told me they were both bad, and I decided to fix them myself to save some money), and now when I start my car either the fan is off even when I adjust the climate control or it's on full blast no matter what I do. It's off more often though.
Before I put everything back together I turned the car on a few times to see if the blower would work and it was stuck on high the whole time, after I put everything back together it stopped being on everytime, but it still turns on sometimes, but not when I use any of the switches. It also doesn't seem to matter where the switches are set before I turn the car on.
What else could be wrong? Can the ECC unit in the dash burn out because of a bad resistor or blower motor? I took the unit out of the dash and looked inside and didn't see anything that was obviously wrong, but I have no idea what I should look for.
I'm anxious to fix this as quickly as possible, I live in the Upper Peninsula of Michigan and even though the weather is nice right now winter is just around the corner and it could start snowing any day. I'd like to have heat in my car before the first snow. If anyone has suggestions please don't hesitate.
Thanks.
Old Nov 4, 2008 | 04:10 PM
Default RE: My heat/AC won't work
I have seen the bad blower motor and resistor burn the ECC up to many times to count.
I would say thats where you problem is.
Old Nov 4, 2008 | 05:33 PM
MI_Marcus's Avatar
If that is the case my next question is, what do I need to know about fixing that?
Old Nov 4, 2008 | 06:22 PM
It the module burned up find a used one and swap it out.
The ECC module just pops out. I slide the radio out and push it out from the back.
Old Nov 5, 2008 | 09:08 AM
Psaboic's Avatar
Used ones can be found at wrecking yards, at carparts.com, and sometimes Ebay
eljarhead
Jul 9, 2014 12:42 PM
tony67
Sep 7, 2011 02:41 PM
jpm2346
Oct 2, 2009 10:22 AM
Lichty17
Oct 11, 2006 09:31 PM
