Heat does not work
Old Oct 11, 2006 | 08:56 PM
Lichty17's Avatar
Default Heat does not work
It has just began to get cold enough to use my heat up here in Minnesota. When i went to use my heat today i could not get air to come out of my vents the 2 lights on top of the REC and A/C switches blinked and i could not get any air to come out. What could possibly be the problem now?
Old Oct 11, 2006 | 09:02 PM
code33's Avatar
Default RE: Heat does not work
Blinking lights mean that there is a code thrown indicating a possible problem. You can pull the codes yourself on the B side of the diagnostic box.
Old Oct 11, 2006 | 09:31 PM
If the blower motor doesn't come on them most likely the motor is bad and causes the lights to flash.
But yes pull codes.
klaus
Apr 25, 2009 08:53 PM
fpa
Nov 20, 2008 03:46 PM
dawnb0415
Mar 10, 2008 07:14 PM
tr_car_nut
Feb 13, 2008 07:58 PM
mtidwell
May 2, 2006 09:15 PM
