Need gas pedal to start... help
Old Oct 18, 2016 | 08:25 PM
96850urbo's Avatar
Thumbs up Need gas pedal to start... help
1996 volvo 850 turbo 150k
Hi All, I need some help trying to figure this out.
What is happening is that I have to prime and pump the gas pedal to get the car to start. After I keep doing this repeatedly it seems to warm up and then will hold idle and I can even drive it. Trying to trouble shoot this problem.
So far I have cleaned the IAC and throttle body.
A little back story is that I stepped on it recently and blew out the intercooler hose up front. I ducked taped that and car ran again, and I have since replaced it. But I am noticing that an issue too is that the car won't boost. I have a feeling that I blew out the CBV on the turbo as well.
I have ran a compression test twice. The first time on a cold motor and got:
170, 165, 170, 170, and 160.
Second time was with a warm motor:
165, 157, 155, 160, 153.
I do notice that the IAC buzzes after I turn the car off. Maybe it needs to be replaced and not just cleaned? The only codes that I am getting is for a misfire multiple cylinders.
Is there any chance that if that a turbo part blew out that it would cause a vac leak that is making the car idle funny (hard to start) or are these two separate problems? Im kinda thinking about as a next step to put in a junk yard IAC in there and seeing if that fixes my starting issue.
Old Oct 18, 2016 | 08:46 PM
tryingbe's Avatar
Only thing pumping the gas pedal will do is to activate clear flood mode, aka, shut the injectors off.
Old Oct 19, 2016 | 02:28 AM
96850urbo's Avatar
I'm not holding the pedal down to the floor. That may turn off the injectors. Pumping it is how I am getting it to start so it wouldnt make sense that the injectors are being Turned off. I think I am going to figure out how to test fuel pressure. But if anyone could answer my question about the turbo affecting idle that would be appreciated. Thanks
Old Oct 19, 2016 | 07:58 AM
tryingbe's Avatar
No. But a loose hose clamp or torn hose can. Check EVERYTHING for a vacuum leak.
Old Oct 19, 2016 | 09:48 AM
96850urbo's Avatar
That hose is exactly what mine did. I was able to drive the car about another mile. And a duck tape job got me the rest of the way home.
Old Oct 20, 2016 | 09:15 AM
firebirdparts's Avatar
You clearly have a hole in the intlet plumbing. The MAF sensors is really far away from the engine, and if there are leaks, the MAF will be wrong. It doesn't take much of an error to prevent idling. When you have the throttle open, the airflow is larger, so the errors caused by the leak(s) are relatively smaller, and it'll run. This is a pretty common problem.
The hoses seem to deteriorate over time, so you may have more leaks than just one. The one right at the throttle has that little sidearm on it, and that is another good one to inspect.
Just to be super clear you may have a vacuum leak, but that is not what I am talking about. I am talking about the plumbing between the MAF and the throttle.
Old Oct 20, 2016 | 12:07 PM
96850urbo's Avatar
Thank you for the explanation and advice I am going to recheck that plumbing.
Old Oct 20, 2016 | 01:39 PM
Cdubbs's Avatar
Can you bring the car somewhere for a smoke test and check for vacuum leaks?
Old Oct 21, 2016 | 03:04 AM
96850urbo's Avatar
Still haven't checked my plumbing yet. I have been driving my old farm truck. If I don't see somethong obvious I am going to see if harbor freight sells a smoke machine. I have tried propane in past no luck.
Cleaner13
Aug 3, 2014 09:34 AM
nigel_miguel
Jul 31, 2012 12:06 PM
shoebox92
Mar 23, 2009 11:24 PM
mike99j
Dec 16, 2005 08:31 PM
