need help- 1993 850 GLT heater problems
Old 12-10-2015, 09:12 PM
firedrop's Avatar
Default blower motor/fan sometimes doesn't turn on
my heater is working sporadically.. i bought this car 2 weeks ago and the heater works maybe 33% of the time. sometimes the fan won't spin at all, and other times the heater works perfectly fine..
i used the diagnostic box (b-1) under the hood and got the following codes
1-2-5
1-2-6
1-3-5
2-1-1
2-2-1
2-2-2
2-3-6
3-2-1
4-1-1
4-1-3
1-2-5 ....... Pass. Side Temp. Sensor Circuit Shorted To Ground
1-2-6 ................................. Pass. Side Temp. Sensor
1-3-5 ........................ No Engine Temp. Frequency Signal
2-1-1 .............. Driver’s Side Damper Motor Position Sensor
Circuit Open Or Shorted To Power
2-2-1 ................. Pass. Side Damper Motor Position Sensor
2-2-2 ................. Pass. Side Damper Motor Position Sensor
Shorted To Ground
2-3-6 ..................... Recirculation Damper Motor Position
Sensor Shorted To Ground
3-2-1 .............. Driver’s Side Damper Motor Active Too Long
4-1-1 ......... Pass. Compartment Fan Overcurrent Or Seized Fan
4-1-3 .............................. Driver’s Side Temp. Sensor
Intake Fan, No Control Voltage
if that's any help to you guys
any help would be greatly appreciated. thank you
Old 12-11-2015, 08:54 AM
firebirdparts's Avatar
Well, if I were you, I would visit the junkyard and replace the controller. But before I did that, I would probably pop it out and jiggle all the wires and make sure it looks good. I doubt that'll help it.
all those items aren't separately shorted to ground, as I am sure you know. The problem is in the brain, which is the only place these things are combined.
Old 12-11-2015, 09:42 PM
firedrop's Avatar
yeah picked one up at the junkyard for $50 and the heater is working now. thanks
Old 12-14-2015, 04:59 PM
boxpin's Avatar
Good job! Thanks for posting the resolution.
Old 12-16-2015, 06:40 PM
firedrop's Avatar
it stopped working again today.. i turned the car off then turned it back on and it was working again, now it's giving me codes
2-1-1
4-1-7
4-1-8
1-2-4
2-1-1
Old 12-16-2015, 10:09 PM
Volvo 850 ECC climate control AC & heater system service manual
Its a good place for the 4-1-1 on your 2-1-1...
malikdrgn
06-24-2013 02:24 PM
Regis W
10-20-2010 11:36 PM
Brendan
06-26-2010 11:28 PM
RangeRoverBoi
02-27-2006 10:55 PM
ddmusic
09-22-2005 09:50 PM
Quick Reply: need help- 1993 850 GLT heater problems
