Need Help!!!!
trying to figure out why my 95 850 glt starts sometimes and idles for a couple mins then dies and acts like the battery is unpluged cause everything resets like my clocks and radio changed fuel pump relay like 4 times i dont think thats the problem we checked the fuel to the injectors all was good i have no idea what else it could be
Help us, help you. Instead of just posting "need help" give a brief description of what you need. It's more likely that someone with some knowledge of the problem will read your full description and give you a hand.
Almost every single poster is looking for some help.
It starts sometimes ?? When you stick the key in does it always turn over but not start or when you turn the key is it dead??
When it starts and idles for a few minutes and dies and you try to restart it does it crank normally, slowly or just click or noting at all ??
Have you had the battery tested to make sure it has the power necessary and when it's running have you checked the voltage of the alternators output ??
Do you have a check engine light on when it's idling or any other idiot light on ??
Remember the answer is only as good as the information you supply
![Wink](https://volvoforums.com/forum/images/smilies/wink.gif)
Sanel30
02-18-2010 09:16 PM
