need help with tps code
Old Oct 13, 2008 | 04:13 PM
scubamike's Avatar
Default need help with tps code
ok my shift up indicator light started flashing and check engine light came on.I scanned and it was code p0120 so I bought new tps and installed cleared code and its doing exactly the same thing can anyone please help me with information thank-you btw it is 95 850 non turbo
Old Oct 13, 2008 | 04:36 PM
Default RE: need help with tps code
I would pull the ECM and clean all connections.
Before you pull it though make sure the ignition has been off for more than 2 minutes before you pull it.
I have seen that cause it but I have also seen a bad ECM cause it as well.
Old Oct 13, 2008 | 04:54 PM
scubamike's Avatar
ok im gonna sound stupid here but what is the ecm and where would I locate it thank you for your help
Old Oct 13, 2008 | 04:57 PM
The ECM is the Engine Contol Module. It is on the passenger side The OBDI ports attach to the box. Remove the top cover and look for one that says bosch remove that one.
Old Oct 13, 2008 | 05:57 PM
scubamike's Avatar
Thank you Tech you were spot on!pulled ECM cleaned contacts and put back in cleared code and its fixed.Your awesomethanks a million for your knowledge.one other thing I disconnected my battery when I was trying to reset the code and now my radio doesnt work I bought my car used 1 year ago any advice on getting code for that?
Old Oct 13, 2008 | 06:06 PM
2 things
1. Make sure after driving it good the code doesn't come back. Sometimes it will. But most times cleaning fixes it.
2. Stop by your local Dealer and ask them to give you the code. You will need to show proof of ownership though.
Most will not charge you. Also pull the radio and see if it is written on the top.
Sorry but that is the only way you can get it.
Old Oct 13, 2008 | 07:16 PM
scubamike's Avatar
ok thanks again for all your help Tech
Old Oct 13, 2008 | 07:40 PM
Ozark Lee's Avatar
Try a couple of things first - look for a card in the owners manual that is about the size of a credit card with 4 numeric digits on it - It should say something like Volvo Audio Systems on it. If:
A) You can't open the glove box.
or
B) There is no such card.
Pop the radio out (Real easy - just take the key and push the two rectangular slots next to the Bass control and the preset number 6 - from there handles pop out and just pull the handles) and look for a 4 digit number written on the radio somewhere with a Sharpie. If you find such a number that is your radio code.
None of my radios leave home without the code written on the radio.
If you can't locate the code the dealer can indeed provide it with either the VIN if it is the radio that is original to the car or the serial number from the radio if it is not. I have themost thieving stealership in the country(List +40% at the parts counter Rick Hendrick Superior Volvo) and even those Ba$t@rds will give me a code for free.
...Lee
240nc
Jan 25, 2015 01:31 AM
RRTEC
Sep 30, 2014 09:13 PM
cja1983
Jul 6, 2012 05:50 PM
jimcashin89
May 2, 2012 12:44 PM
sdm952
Aug 23, 2008 04:40 PM
