Need a new Cat.
Old Apr 4, 2011 | 01:16 PM
ajene's Avatar
Default Need a new Cat.
I need a new cat but I do not have $800 does anyone know of a replacement that will not brake the bank. I called a locate shop and the told me he would not do it(cut out the old one and put a cheap replacement in) "it would set off the engine codes and cost gas mileage in half. But if I wanted to do it bring it on in.
Old Apr 4, 2011 | 01:20 PM
gilber33's Avatar
summitracing.com
jegs.com
ebay.com
google.com
All you need is a cat with the correct inlet and outlet dimensions and weld it in place.
JimKW's Avatar
Yes. I just went through this on my 97 R. I ordered three from fcpgroton and had to return each one, so don't go there. I got one at Advance Auto and it didn't work either. Finally I went to Midas or Meineke, can't remember which, and had them cut my old oneout and weld a new on in using my pipes and O2 sensors. Cost less than $300 which was cheaper than all the other ones I tried. That was about four months ago and have had not problems.
Old Apr 4, 2011 | 08:33 PM
bostongrun's Avatar
Try a junk yard. There are lots of old Volvos around. Shouldn't cost more than sevnety-five bucks.
Old Apr 4, 2011 | 09:02 PM
91shelby's Avatar
for 800$ you could get a nice bolt on aftermarket setup
Old Apr 5, 2011 | 01:17 AM
boxpin's Avatar
Where do you live? If its Calif you have to have an OEM or EPA compliant FOR YOUR CAR. Nothing else. I failed because I have a 3" chevy cat on mine. Had to make an angled OEM to pass.
I have another OEM cat if your interested, PM me.
Old Apr 5, 2011 | 03:41 PM
ajene's Avatar
I went to the summit racing store in GA I live in atlanta ga and picked up a magnaflow converter just need to put it on. If it does not work i will give you a call
Old Apr 6, 2011 | 07:27 AM
Rickford's Avatar
Question about cats while we're on the subject. A independent Volvo mechanic said I needed a new cat cause mine was broken and loose on the inside and ranting. It looks great from the outside. He said it happens to a lot of them. It's a 94 850na w/about 175k. Ya think this is BS?
Old Apr 6, 2011 | 09:24 AM
JimKW's Avatar
That's what happened to mine. Rattled like crazy, but looked fine on the outside.
Old Apr 6, 2011 | 02:14 PM
autoxray's Avatar
I am also dealing with the potential having to get a new cat. I keep setting a code (can't remember as I am on work trip to Eastern Oregon) that basically says there is a problem with my cat, Bank 1 is out of range.
Now this either means my cat is bad (plugged) or I have a O2 sensor not reading correctly. Not really sure how to isolate this and make the correct decision.
Boxpin, my '96 is a CA car in that it passes CA emissions and I know that FCP Groton and the others sells cats for the other states, but not a CA compliant car. Might be interested in your cat, if that is what I need.
PM me for details. Ray
stevenro64
Apr 19, 2011 05:23 PM
tilsacarcib
Jul 9, 2009 01:53 PM
cj351stang
Apr 15, 2009 07:47 PM
Miatamon
Nov 17, 2007 06:42 AM
bli745
Aug 3, 2006 11:32 PM
