NEED SOME HELP: a few important questions
Old Dec 4, 2006 | 06:51 PM
hockeymatt2727's Avatar
Default NEED SOME HELP: a few important questions
wats up everyone im a new member and i need some help! i currently own a 97 volvo 850 (non turbo) with 159,000 miles and i have a few problems with it:
1. at around 150k i noticed the ABS and traction control light came on. it would stay on for a few seconds then would shut off. BUT prolly for the last 2 months it has stayed on and not gone off. i havent been able to test the ABS yet since we have not had any bad weather. should i get this checked out or what? any info would help.
2. my passenger side light is cracked. it looks like its just the lens but would i have to replace the entire light, and if so where would be the cheapest place to find a replacement?
3. lastly, for some odd reason when i start up my car, the engine will automatically rev to 1500rpm and then fall back to 0. im not stepping on the gas at all. im just curious why it does this and if there should be any concern
thanks, hopefully you can help
Old Dec 4, 2006 | 08:40 PM
Default RE: NEED SOME HELP: a few important questions
1.ABS module is bad.
2. Try E-bay for just the glass. (I assume the Headlight)
3. Does it stall? or just idle down?
Old Dec 4, 2006 | 09:08 PM
it doesnt stall at all, basically what happens is il start the car up, a few seconds later it will rev slowly/quickly to 1500 rpm then will go back to 0 and the car will stay running. i was just curious
Old Dec 4, 2006 | 09:34 PM
If it idles a little high when first started cold that is normal.
Then it will drop to about 700 RPM.
Old Dec 4, 2006 | 11:54 PM
info2x's Avatar
How can the car be at 0 RPM and not have stalled. Something just doesn't make sense...
Old Dec 5, 2006 | 12:31 AM
B1mmer's Avatar
It sounds like to me has an idle problem that the idle is jumping all over the place. Somtimes this is caused by a dirty Mass Air Flow sensor or a vacuum hose that is cracked. - AB
Old Dec 5, 2006 | 12:54 AM
JPN's Avatar
JPN
Welcome to the forum (I'm rather new as well).
If the RPM drops to zero and the engine is still running, the RPM signal sensor is probably faulty, or tach mechanism may need repair. 850's fast idle kicks in during very cold weather and doesn't last as long as other mfgs' cars. Let the engine idle for a couple of minutes and wait driving away until the idle stabilizes. In freezing days in Chicago, I let the engine idle as long as 7 minutes or until the temp gauge begins to rise. I might be just wasting fuel and polluting the air, but I don't feel comfortable driving away when the engine is ice-cold.
The ABS module for Volvo's are really fragile. Mine is also shot and it works only 1 out of 10 times. I cleaned all wheel sensors, serrations and connectors and the ABS still fails 9 out of 10 times. There seems to be some ABS module repair services, you could try them:
http://www.autoecu.com./
http://home.earthlink.net/~vicrocha/
You could also try a junkyard for the lens, though 850's are rather rare at those places.
Good luck,
JPN
Lansdowne
Sep 22, 2014 01:02 AM
Caxtin
2001-2013 model year XC70
Feb 23, 2013 10:09 PM
range hadies
May 26, 2012 09:14 PM
range hadies
May 19, 2012 11:52 PM
VanTassel.x850x.
May 3, 2012 04:52 PM
