New shocks new vibration
Old May 17, 2011 | 08:50 AM
daver80's Avatar
Default New shocks new vibration
95 850 wagon 193K miles, just put a set of Bilstein Touring shocks on the rear, now I feel a slight vibration I never fealt with the old shocks. I pre pumped the shocks on the bench a couple of times, maybe only twice. Could other worn rear end stuff be making this vibration more evident? Wondering if I need to take them out and really bench pump them more. Thoughts? Thanks, Dave
Old May 17, 2011 | 10:19 AM
docmot's Avatar
With a stiffer shock, you could now be feeling tires that are out of balance.
Old May 17, 2011 | 10:31 AM
+1 Check tires.
Old May 17, 2011 | 10:34 AM
MattyXXL's Avatar
Is the vibration only happening when your rolling?
Old May 17, 2011 | 02:26 PM
daver80's Avatar
Default vibration
I kinda doubt it's a tire issue- Set of 4 are about a month old and were smooth last week. I'll check tonight-rolling vs power on. They are "touring" class- are they really stiffer than stock? No idea what was on there before...D
Old May 18, 2011 | 12:04 AM
gdog's Avatar
The TCs are only slightly firmer than stock. Very nice choice; what i have on both my vehicles. Should not need to "bench pump" them...
Curious, why did you only install the rears? Usually do shocks/struts as a set.
RE: your vibration; your rear suspension is somewhat touter now so any issue is amplified a bit. I would go back to your tire place and ask them to recheck the balance; should be no-charge.
Old May 20, 2011 | 04:05 PM
daver80's Avatar
Default vibration
gdog- originally I heard some rattling in the rear and thought I'd replace shocks on all 4 corners, Got the rear Bilsteins for a great price, thought I'd start with the easy, cheap fix first (rears). Front right needs a spring seat. to do the whole front with mounts and seats and alignment I figured I was looking at close to 500 bucks parts and alignment. It rides very nice except for the squeeky from the front right. Looking back I should've just left the rear alone- rattle was hatchback panel and rear door rattles inside. I'm going to just replace the spring seat and say good. Move onto other repairs- like heater core. I do plan a trip to my tire place for a re-balance. D
umbalaxx
May 31, 2015 12:32 PM
halcyon419
Mar 13, 2009 12:53 PM
ocean238
Apr 17, 2008 06:20 PM
parrym
Jul 13, 2007 12:51 PM
jdbs3
Jul 3, 2006 01:06 AM
