New Starting issue
Old Jul 6, 2009 | 12:58 AM
Chebucto's Avatar
Default New Starting issue
Ok, this only happens every 30 or so starts, but I can turn the engine over and it will sound like it is starting, only it will rpm down and stall. I try to start and I get a type issue you would have with a flooded car....I wait 5 or so min and bang...starts with no problem. Ive cleanded the ICV.....but it ticks very loud at times....any Ideas?
Old Jul 6, 2009 | 01:00 AM
Chebucto's Avatar
BTW....NO codes found after each of these no starts....checked each time with my OBII reader.
Old Jul 6, 2009 | 01:10 AM
850tony's Avatar
bad coil?
Old Jul 6, 2009 | 01:12 AM
Chebucto's Avatar
that is found near the upper fender on the drivers side right?...but would I not get some sort of code if it failed?
Old Jul 6, 2009 | 01:23 AM
Chebucto's Avatar
BTW...could this account for having a rough idle?
Old Jul 6, 2009 | 02:27 AM
850tony's Avatar
yes and yes
and it wont always throw a code.
Old Jul 6, 2009 | 10:28 AM
bestharry's Avatar
when was the last tune?
A bad wire from coil to distributor can result in same symptoms. Try to reroute it and that might keep the leaky spot from arcking for troubleshooting purposes.
Old Jul 6, 2009 | 12:28 PM
850tony's Avatar
that will fix a rough idle, his odd random hard starts are interesting though...
might be time for a fuel filter.
Old Jul 6, 2009 | 04:43 PM
meb7070's Avatar
Side note on the coil issue, back when i had my jeep i went through 3 of them before i realized it was a bad connection, sprayed in some contact cleaner and it was as good as new.
So, long story short, since it is intermittent you can go through and check all the wires and might as well do a tune up while you are at it like mentioned above.
VolvoMonki
Nov 20, 2007 06:10 PM
JasonCase
Mar 11, 2007 01:46 PM
Anns V70
Feb 13, 2007 10:40 AM
Jdub
Aug 30, 2006 09:48 PM
