New volvo owner
Old Apr 27, 2005 | 05:19 AM
mevans035's Avatar
Default New volvo owner
So I just got my first volvo, a black 1995 850 turbo. I have about 3500 bucks to put into it, but I don't know where to go or what to do first. Any suggestions?? I don't know much yet, but I'm ready to learn
Old Apr 27, 2005 | 10:07 AM
sghokie's Avatar
Default RE: New volvo owner
Clean the flame trap, change the oil, check the spark plugs, etc.
Old Apr 27, 2005 | 10:09 AM
Check the engine mounts and the C/V boots.
Also check all the breaks and Belts.
Make sure the timing belt has been done when it was supposed to if not then do it fast.
Old Apr 29, 2005 | 09:49 AM
sghokie's Avatar
Tech, you mention the timing belt. Mine was done about 5 or 6 years ago and about 70k ago.
So its due for one.
Couple of questions about it.
Is the engine an interferance engine?
I looked at replacement procedure for it, is it a DIY kind of job or am I bound to get into trouble doing it?
What is the going rate for a t belt replacement?
Old Apr 29, 2005 | 10:31 AM
Yes it is an interferance engine.
If you have done any work like this before you should not have any problems.
As long as you make sure the timing marks are lined up before and after you should be fine.
I would also suggest to replace the hydrolic tensioner.They should be replaced at the second intervial.
Here is a link to replacing the belt.Im not sure if it is the same one as you looked at.
http://www.babcox.com/editorial/ic/ic60326.htm
Old Apr 29, 2005 | 11:13 AM
JimKW's Avatar
I'm not sure but I think the charge is about $300 for the timing belt replacement that I just had done on my V70. My 850 is due in about 10K miles. After reading that, I'm certain that I will pay somebody else to do it. I'm just not that mechanical. My daughter is marrying a mechanic that is getting out of the Army next week. Maybe I can get him to do it.
SHBazTBone
Apr 18, 2014 04:25 AM
shimby
Nov 21, 2008 07:14 PM
Crutch
Oct 2, 2008 01:16 PM
U4IC60R
Apr 23, 2007 09:58 PM
richard
Jul 5, 2005 12:53 PM
