Newbie from MNL Philippines
Old Oct 17, 2014 | 08:50 AM
ecnirp91's Avatar
Default Newbie from MNL Philippines
Hi good day folks
am a newbie from Manila Philippines
found this forums while searching over the net!
i had the chance to own a 1997 850 GLE matched with automatic tranny.
im using the car for two days now and ive noticed that after a cold start when i shift to drive (D) its stuck on 3rd gear every single time but sometimes when i go to a full stop shifting from D to N then D it would go to its normal shifting but mostly its on limp mode.
is there any quick fix that you can share?
thanks for your input.
cheers!
Old Oct 26, 2014 | 07:15 PM
Hi and welcome to the forum.
Does the car have any stored codes?
Add the heater core to this list and you should be fine.
Old Oct 27, 2014 | 06:40 AM
Welcome to the forum
You might have a PNP switch that's acting up and causing the shifting problem. If you turn the ignition on without starting the car and "row" through the gears from end to end a number of times it might help. Not suggesting you slam it from end to end but slow enough to feel the detent for each gear.
Info on PNPs - > https://www.google.com/#q=volvo+pnp+switch+cleaning
Not saying it is the PNP, just a guess it might be. Do you have a check engine light on or the flashing up arrow coming on when it's acting up ??
Titch79
Jul 15, 2012 07:50 AM
sabine
Oct 1, 2009 03:11 AM
MMMickey
Jun 1, 2009 10:50 AM
JackFlash
Jun 1, 2009 10:45 AM
frontsight
Dec 1, 2005 06:47 PM
