Nipple on the back of Air Intake Hose
Old Nov 19, 2010 | 06:52 AM
Henry10's Avatar
Default Nipple on the back of Air Intake Hose
This is the hose from the airbox to the Turbo. This hose has in fact 2 nipples
1- Nipple # 1 is underneath the hose: According the hood's Vacuum Diagram, a line (blue line in Diagram) runs from this nipple to the TCV (Turbo Control Valve). My line is black, which means that previous owner probably replaced vacuum piping. This is fine.
2- Nipple # 2 is in the back. My Vacuum Diagram has no other connection to the Air Intake. From searching these Forums, I hear that NA Volvos have a line to the flap valve. Mine is a Turbo. What is this Nipple for? I have capped this Nipple.
I looked at FCP Groton's picture of Air Intake Hose picture for my car. I don't see this Nipple # 2 on it. Is it possible previous owner installed the hose for the NA Volvo?
Pls advise.
Old Nov 22, 2010 | 10:39 PM
Henry10's Avatar
Am I blowing something up by capping this nipple?
Old Nov 22, 2010 | 10:44 PM
Cap it for now. There is 3 different hoses for the turbo cars. Someone might have replaced the one with that one and there is an extra nipple.
Old Nov 22, 2010 | 11:05 PM
Henry10's Avatar
Thank you.
Old Nov 22, 2010 | 11:30 PM
Henry10's Avatar
On another note -- i just recently discovered that previous owner (or mechanic) had taken out the vacuum hose the connects the PTC with the manifold vacuum tree, next (downstream from) to the TB. This means that crankcase vapors were not being returned straight to the intake manifold, at 80 degrees temperature, rather than via Turbo? So until the car warmed up the pressure had no release?
I also cleaned the PTC (without removing it).
Connecting the hose as it should be plus cleaning the PTC made the oil-tube smoke go away (almost). I will be doing the PCV soon.
Old Nov 23, 2010 | 08:59 PM
Glad you found that.
Sweet T5R
Apr 23, 2013 10:11 PM
ahilfman
Apr 1, 2012 05:16 PM
apeman
May 16, 2009 07:36 AM
Sofar.
Feb 9, 2009 02:56 PM
rquinonez32
Sep 30, 2008 02:08 PM
