PTC nipple: anatomy?
Old Mar 29, 2012 | 05:08 PM
ahilfman's Avatar
Default PTC nipple: anatomy?
Here is a pic of the ptc nipple i am cleaning. I understand basically what it does, however where does the blue arrow go? It does not feed into the inside of the cylinder (red). Is it clogged, or is there a gated mechanism?
Attached Thumbnails PTC nipple: anatomy?-ptc.jpg
Old Mar 29, 2012 | 07:33 PM
Clogged. Use a narrow sharp object to clean the carbon out.
Old Mar 31, 2012 | 10:12 PM
Maybe these might help.
The PTC itself should be hollow. It's used to create a vacuum to pull crankcase vapors into the intake to burn them. You just need to carefully scrape, drill or soak all the crud out of the inside of it.
Attached Thumbnails PTC nipple: anatomy?-ptc-valve-location-intake-tube.jpg   PTC nipple: anatomy?-turbo-vacuum-hose-diagram.jpg
Old Apr 1, 2012 | 12:02 AM
Psaboic's Avatar
Are these fittings on a turbo model or only on an N/A model. Never seen one on my 1995 turbo? If so where is it found so I can clean it...thanks
Old Apr 1, 2012 | 12:44 AM
ibified's Avatar
Psaboic: of you follow the tube from the pcv system back to the intake, you will see the ptc with hoses attached on the intake tube right before it connects to the turbo.
Old Apr 1, 2012 | 10:42 AM
Psaboic's Avatar
Thanks!
Old Apr 1, 2012 | 05:16 PM
It's in the intake tube just before the turbo. If you lean over the engine down form the upper engine mount you should see it down there. It's best to remove the whole intake tube and once out remove the PTC from the tube. If you try to pull it out in place you might damage the rubber fitting it sits in. It's also much easier to reinstall it with the tube out so you can visually inspect it to make sure the rubber seal is good. Some people have used a light coating of silicone sealant at the seal just to make sure there is no leak.
G_Martin
Apr 13, 2015 10:02 AM
Sweet T5R
Apr 23, 2013 10:11 PM
Henry10
Nov 23, 2010 08:59 PM
apeman
May 16, 2009 07:36 AM
Sofar.
Feb 9, 2009 02:56 PM
