No AC on 94 850 wagon
Old Jul 20, 2006 | 12:40 AM
tracedog67's Avatar
Default No AC on 94 850 wagon
Fellers,
I looked at a gorgeous burgundy '94 850 wagon Turbo with 95k miles today but the AC didn't blow cold. Can i easily add freon to this car? How can i tell if the turbo is working properly? At what RPM does the turbo usually kick in?
thanks
Tdog
Old Jul 20, 2006 | 12:48 AM
Default RE: No AC on 94 850 wagon
It is easy to Add Freon. The evaperators are Known to leak on these cars.
The turbo kicks in at different times. Most of the time you can hear the turbo kick in.
Does it have a turbo Guage?
If so does it move?
You can also usually feel it kick in.
Old Jul 20, 2006 | 12:59 AM
tracedog67's Avatar
Would this car use R134a already or would it need to be converted? Yes the turbo guage did move but i didn't get to get the car out on the open road so i didn't get a good feel for the engine.
Old Jul 20, 2006 | 01:03 AM
Yes it is 134A already.
You should feel a good boost in the city when getting on it pretty hard from a stop.
You will feel it start taking off then you will feel a pretty good boost in acceleration.
Old Jul 20, 2006 | 01:08 AM
tracedog67's Avatar
can I use the typical can of freon available at Autozone or walmart to recharge the AC? Where is the valve to add the freon?
thanks for your quick reply, where are you located?
Tdog
Cincinnati, OH
Old Jul 20, 2006 | 11:44 PM
Im in Flordida.
Yes you can use a can of that stuff.
I would add one can to start with.
greenman86
Nov 8, 2014 07:27 AM
VolvoBB
Jul 28, 2013 11:59 AM
boxpin
Oct 10, 2009 03:30 PM
yellow95
Apr 20, 2006 11:15 AM
yellow95
Apr 18, 2006 08:52 PM
