NO BRAKE LIGHTS!
Old Nov 1, 2007 | 05:57 PM
jquick1's Avatar
Default NO BRAKE LIGHTS!
checked fuses,change relay, checked brake switch has power, when you mash pedal you get power to yellow wire did not check other wires yet. help! could someboby tell me which wires to put power too, so i can check the switch !![&o][&:]
Old Nov 1, 2007 | 07:00 PM
Default RE: NO BRAKE LIGHTS!
One of the 2 wires will have power all the time the other one will get power when the pedal is pressed.
You aren't testing the switch with the vaccum line are you?
If so thats not the right one the one above it is the one you need.
Old Nov 1, 2007 | 07:05 PM
jquick1's Avatar
the one with vac. is above my brake switch. not testing that one. can you tell me what the yellow wire goes to.
Old Nov 1, 2007 | 07:13 PM
Not sure at the moment would have to look it up.
Do you have power to 2 wires with the pedal down?
Does the shift lock work properly?
Old Nov 1, 2007 | 07:44 PM
jquick1's Avatar
red wire is hot, when i mash pedal i get power to the yellow wire, have not checked others yet. i want to run wires to the others to make sure the brake light work. i unhooked the safty switch about six months ago. thanks
Old Nov 1, 2007 | 07:47 PM
Oh ok because if the shiftlock worked then the lights should have.
But also there is a bulb failure relay in the trunk that might be bad.
Old Nov 1, 2007 | 08:18 PM
jquick1's Avatar
where is that relay in trunk
Old Nov 1, 2007 | 08:28 PM
robrike's Avatar
I think it is on the left side of the trunk behind the carpet near the antenna power motor. I had all my brake lights go out at once I assumed. The bulb light was on. Checked and resoldered connection for the malfunction indicator relay but ultimately scrubbing the bulb sockets and replacing all bulbs with those from a 4 pack solved my problem. 3rd light required some contact cleaning and bending the copper to make a better connection.
That malfunction relay is behind the carpet on the left side of the trunk.
Old Nov 2, 2007 | 08:41 AM
Psaboic's Avatar
Yep, a friend had the same issue on a 94 model. It turned out to be the relay, and yes, it is on the left side of the trunk near the power antenna.
Good luck,
Glenn
Old Nov 2, 2007 | 10:55 AM
jquick1's Avatar
i fixed it, took the brake switch apart, and cleaned contacts with sand paper. works now thanks everybody
Old Nov 2, 2007 | 01:13 PM
JPN's Avatar
JPN
Well done!!!
JPN
Old Nov 3, 2007 | 10:18 AM
Psaboic's Avatar
Ditto!
aznyaz
Jan 9, 2015 02:38 PM
zinko
2001-2013 model year V70
Feb 11, 2014 07:18 AM
Scott V
Jul 21, 2013 02:28 PM
Mellott
Jun 13, 2011 11:41 PM
chrystald423
Mar 27, 2010 08:05 AM
