No A/C Help Please
Old Aug 26, 2009 | 08:34 AM
cBobs94850T's Avatar
Default No A/C Help Please
My Problem is that I cannot get the A/C compressor or the Fan to RUN. I have tried shorting out the Low Pressure switch ( nothing) tested the A/C Relay (good) de-lidded the Relay and put it back into the circuit to test it's operation. The Relay activates when the A/C switch is turned on and when it is in the AUT Mode. It does not activate in the Deforst Mode ( should it) So think my ECC is good. Tried measuring voltage at the Low Pressure switch and got -.1 and 10 then measured the High Pressure Switch and Got 6.25, 6.28 and 0 volts ( looking at the connector upside down with the metal retainer clip pointed towards the drivers side) Would like to try and directly activate the compressor by appling voltage directly to it to see if the cluch pulls in but don"t know with wire carries the voltage and I don't want to do any damage. I don't know what to try next Any suggestions ??? forgot to mention there are no DTC's
Red 94 850 Turbo Thanks
Old Aug 26, 2009 | 08:38 AM
gilber33's Avatar
Try searching first, there are TONS of threads on A/C problems.
Old Aug 26, 2009 | 08:43 AM
I did. Have read everything I could find (tons info on several forums) need more specific info
Old Aug 26, 2009 | 12:50 PM
volvo4mula's Avatar
You can directly power up the clutch on the compressor if you need to. The overheat switches on those would sometimes go bad and not pass power. Not saying that your problem is that simple.
If your cabin fan won't work at all I'd check the resistor for the fan.
Also keep in mind that there was an updated ccm for that car with updated power supply as well.
Old Aug 26, 2009 | 01:29 PM
Thanks for the reply, I need to clarify the cabin fan/blower works fine I'm talking about the raidator fan that's supposed to come on with the A/C
Also where is the overheat switch and how do I test ??
mrlefler999
Mar 8, 2021 02:07 AM
MNWILD
Sep 10, 2020 11:29 AM
ericsb210
Mar 30, 2010 09:43 PM
Sanel30
Feb 18, 2010 09:16 PM
Epr7339
Jan 6, 2007 12:25 PM
