no check engine light, no smog certificate
Old Jan 16, 2010 | 03:48 PM
dahubb's Avatar
Default no check engine light, no smog certificate
my 1993 850 Volvo .
went get car smogged , everything seemed ok except the check engine light did not light up when ignition was turned on.
Are there individual bulbs for each icon?
help please
Old Jan 16, 2010 | 05:54 PM
boxpin's Avatar
Yes they are individual.
Old Jan 16, 2010 | 07:15 PM
boxpin's Avatar
Here is the back of the cluster
Attached Thumbnails no check engine light, no smog certificate-copy-img_0508.jpg
Old Jan 16, 2010 | 09:11 PM
dahubb's Avatar
Default check engine light
Thanks Boxpin for the pic.
Can I reach it from under the dash, or do I have to pull the dash?
cheers
Dahubb
Old Jan 16, 2010 | 11:19 PM
boxpin's Avatar
Pull unfortunately. Its really not too tough. You can get the cluster out by pulling the pad off from the drivers side all the way to the passenger Airbag. It can be lifted enough to get it out. I have done it twice. I cant remember where I found the instructions to do it but it was a forum.
Old Jan 18, 2010 | 06:22 PM
dahubb's Avatar
Default thanks , NEXT PROBLEM,CHECK ENGINE LIGHT ON
Replaced bulb, now check engine light on all the time.
checked OBD, A 2, 1-1-1 = no faults
Tried to reset by holding button down for 7 seconds x 2
Light still on.
Does A- 2 only affect the CEL ?
Help please
Dahubb
uxicorp
Apr 28, 2014 01:20 AM
frstephen1
Nov 1, 2013 06:50 PM
conor07
Jun 29, 2010 03:01 PM
ROBLU540
Apr 19, 2008 10:35 AM
sbagdasa
Sep 1, 2005 08:37 PM
