no hot or cold air
Old May 29, 2009 | 02:27 PM
  #21
bestharry's Avatar
There is a joint on the wires going to blower motor that tends to give up. Check that and the connector itself to the motor is known to get sparky. Try to get the motor out and you will see what i mean or just wiggle the connector on the motor with blower and ignition switches to ON position.
For radiator, $500 sounds too high to me. The new radiator shouldn't be more then $200 and its fairly easy to throw it in. So, If you are ready to get your hands little dirty for the sake of your bank balance. Do it yourself, This forum is always there to help you at any stage.
Old May 29, 2009 | 02:29 PM
  #22
850tony's Avatar
^^^ true.
we are always here to help. if you do end up doing the work your self i can PM you my cell number if it would be of help.
Old May 29, 2009 | 02:31 PM
  #23
850tony's Avatar
here is an awesome write up if you are interested in what its gonna take
https://volvoforums.com/forum/volvo-850-16/1997-volvo-850-non-turbo-automatic-radiator-write-up-30589/
Old May 29, 2009 | 08:30 PM
  #24
nonsense619's Avatar
i wouldnt use a rad. sealer.i agree with tony850 look to see where the leak is coming from.could be just a hose.RULE #2 when going to a shop.dont look clueless.if you know what is wrong research it a bit.you will get milked.i understand you are a novice but the rad. is not too hard of a job.just time consuming.
cutypie
Oct 26, 2011 05:29 PM
elbert
Oct 18, 2011 10:54 AM
Dennis Bor
May 30, 2011 11:14 AM
beardo265
Sep 27, 2007 09:24 AM
