No lights/blinkers/power mirrors
Old Apr 29, 2009 | 05:22 PM
volvolini's Avatar
Default No lights/blinkers/power mirrors
hi everyone!
I am posting in regards to my friends 96 850. Something strange has happend to his car. His headlights stoped working (high beams are ok), his blinkers stoped working (but if he puts hazards on then all 4 are fine) and his power mirrors stoped working as well. All this together. Is there a simple solution that someone already found?
Old Apr 29, 2009 | 09:53 PM
Was the ABS light on as well?
The electrical part of the ignition switch might be bad.
Old Apr 29, 2009 | 10:35 PM
My 960 does things like that when the ignition key does not return all the way to the run (II) position after I start the car. It does not spring back all the way so I turn it back a little and everything works again.
Old Apr 30, 2009 | 06:42 AM
volvolini's Avatar
@tech, yes his abs light is on as well.
@rspi, thanks for your input, could be a switch. At least that is easy and fairly cheap to replace.
Old Apr 30, 2009 | 07:43 AM
S70driver's Avatar
Has your friend checked the blinker fluid level? It might be low, or emply. Might want to check that out.
LOL, J/K.
Old Apr 30, 2009 | 06:54 PM
Most likely the ignition switch is bad. (electrical part)
Old May 1, 2009 | 11:52 AM
volvolini's Avatar
Thanks guys, it was bad ignition switch and it's taken care of now.
Old May 1, 2009 | 07:52 PM
Congrats!!
TexFinn
Sep 22, 2009 08:08 PM
Obelix
Sep 9, 2009 07:23 PM
walpoo
Jan 22, 2009 03:44 AM
jittest1
Nov 12, 2008 10:53 AM
