Noise behind right headlight
Old Jun 17, 2011 | 11:59 AM
happyhunter's Avatar
Default Noise behind right headlight
I've been hearing a grinding noise right behind my right side headlight assembly. It sounds like something is running and about to fail. At first I thought it was coming from the alternator or power steering pump. But then I noticed it makes the noise when the engine is not running. What is in or near the headlight assy that would make that noise?
Thanks,
HH
Old Jun 17, 2011 | 12:03 PM
MattyXXL's Avatar
Do you have head light wipers?
Old Jun 17, 2011 | 12:45 PM
Yes, I do have them. They are not moving when I was investigating hte noise, but then again they may be broken.... I really do not care about the light wiper so I've never checked if they work or not...
Do they come on when you turn on the normal wipers or is there a seperate switch for the light wipers? My normal wipers work alright, they are not always on.
Thanks,
HH
Old Jun 17, 2011 | 12:59 PM
I just looked at it. The wiper was stuck under a plastic tab below the headlight. I unhooked it and it made 2 swipes and stopped making the noise. I guess it needed to "park" maybe??
I ran the wipers for a few seconds and never saw the headlight wipers run at all. What makes them go?
Thanks,
HH
Old Jun 17, 2011 | 02:07 PM
shamrock1959's Avatar
Default noise behind headlight
The headlight wipers only work when the screen washer is operated and I think lights on.
Old Jun 17, 2011 | 03:25 PM
MattyXXL's Avatar
They will go every time you use the washers. they dont move with the reg wipers.
This is a common problem, after replacing my motors 3 times over the last 16 years I just pulled them out and got the trim without the holes from the u-pick
You can disconnect the plug to the motors and never have to worry about them again.
Give me a couple minutes and ill tale a pic of the plug you need to pull..
Old Jun 17, 2011 | 08:23 PM
matt01's Avatar
sounds like if its not that then its your sas/EGR pump.
supposed to run when the cars cold, can make screeching noises, grinding, but it shouldnt be on all the time.
Eventually it may give you a CEL.
Old Jun 18, 2011 | 04:37 AM
firefighter850's Avatar
mine does the same, i dont think its the wipers mine are broken off neway but ive never thought anything of it
cp54
Jan 5, 2024 10:08 AM
jmshelby
Nov 22, 2014 09:39 AM
nih
Jan 17, 2011 04:41 AM
mmlco
Aug 7, 2009 07:08 PM
gooproduct
Oct 26, 2007 07:29 PM
